1:48 Apollo Display
Discussion in 'Space & Aeronautics' started by McPeek, Jul 7, 2006.
  1. Bengt F
    Bengt F Active Member
    Lunar Rover
    Hi milenio3,
    The Lunar Rover was kept inside the lower part (the descent stage) of the Lunar Module (the LEM, for Lunar Excursion Module) during the space flight, behind a hatch to the right of the ladder. It was neatly folded for storage and was un-folded as it had been released and lowered onto the Lunar surface from the LEM.
    If you have problems with accessing the Rover card model, send me a PM and I will mail the pdf-file to you ASAP.
    Bengt :wink:
  2. McPeek
    McPeek Member
    milenio3 wrote:
    Bengt would be correct and here are a few photos so you can see the location of the lunar rover on the LEM.
    This is an artists concept from Grumman,
    And this is a photo of the pre-flight checkout of the LRV for Apollo 15,
    Deployment sequence,
    Bengt wrote:
    Thank you sir.:grin:
  3. milenio3
    milenio3 Active Member
    And I THOUGHT I was a NASA fan.
    Thanks guys!
  4. Bengt F
    Space In Miniature Series
    Hi all NASA and Apollo fans,
    For in-depth descriptons and the most accurate pictures for super-detailing, I can recommend Mike Mackowski´s book series "Space In Miniature", available from his web site.
    Book #6 "Apollo Command and Service Module - A Guide for Scale Model Builders" is very helpful for detailing the Apollo CSM.
    Bengt :|
  5. Hans Christian
    Hans Christian Active Member
    Oh pretty please, send also the file to me sir!!! at raziel404_ben@yahoo.com
    I also need the LRV, I'm now preparing for an exhibit here in our school, and the LRV would be needed to complete the project Apollo section. Thanks!
  6. Bengt F
    Lunar Rover
    Hi Hans Christian,
    Sure, no problemo - I´ll send the files I have right away.
    Bengt :grin:
  7. Hans Christian
    Yippee!!! Thanks!!! :grin:
  8. McPeek
    McPeek Member
    Display Stand
    Here is the latest addition too the Saturn V.
    I used 1/8" cardboard for the upper and lower deck and the rest is 110 lbs. card stock.
    This was the first time I tried too enlarge anything and I must say that it turned out better than I expected.
    Now it is time too do some work on the service module.
  9. Bengt F
    Saturn V LUT Base
    That´s a mighty fine LUT base you have designed - does the rocket´s engine bells rest on it or does it hang on the four supports on the sides?
    Amazing piece of work.
  10. Dnlgtr
    Dnlgtr Member
    I too am a NASA fan. I should have said this earlier.
    I used to LIVE on a NASA base. My father WORKED for NASA from 1962 until his death in 1991. I still live only a few miles from the base.
    CAre to guess which base??
  11. McPeek
    McPeek Member
    Bengt Wrote:
    The display stand is the work of Roman from Paper Warbirds. It is available at his site or Jonathon Leslie has a link from his site.
    Edit:Link too model, here
    Bengt Wrote:
    The model rests on the four supports.
    Dnlgtr Wrote:
  12. Dyna-Soar
    Dyna-Soar Member
    Greenbelt, Wallops Island ?
  13. Bengt F
    LUT Base
    Forgive my complete incompetence. I have seen Romen Seissler´s model on his site . . . what was I thinking?
    You´ve done a great job of enlarging and building it, though.
  14. McPeek
    McPeek Member
    Thats quite alright my friend. I just didn't want too take credit for something I didn't do.
    Thanks. :)
  15. Dnlgtr
    Dnlgtr Member
    Dyna-Soar is correct. I use to live on Wallop's VA. NASA base. And still live less than 20 miles from there!!
    It was fun getting to ride my bike all over the base.
    And now ot might be used as an emergency landing sight for the shuttle if the plans go through!
    Greenbelt Md's Goddard is 'Parent' of Wallop's now and some do call Wallop's Goddard south or Goddard Wallop's facility.
    I just found a book about Wallop's that was published by British authors!!
