1:33 Scale AN-2 GPM-126
Discussion in 'Radio Control & Other Propulsion Methods' started by meatbomber, Nov 22, 2008.
  1. meatbomber
    meatbomber New Member
    Hello Zealots :)
    i`d like to present to you my latest flying papermodel built with well not paper but again durobatics foam:
    a GPM 1:33 scale AN-2
    She`s my most scale looking bird to date! The GPM plan is easy to build and really catches the shape of teh bird perfectly!
    Wingspann 540mm
    Wing Area 6dm²
    Weight 36g (all up flying weight)
    Wingloading 6g/dm² (real indoor slowflier)
    7mm brushed motor with 4:1 gearing, Microinvent 6030 carbon prop wth diameter reduced by 12mm for ground clearance
    The rest is stock kyosho Minium equipment.
  2. David H
    David H Member
  3. tomazs
    tomazs New Member
    :eek::eek: DAMN :eek::eek:
    cuold you add some blueprints about r/c planes o something what you use to this plane
  4. meatbomber
  5. redhorse
    redhorse Member
    That's beautiful! Do you have a homepage somewhere with all of your models?
  6. meatbomber
    Thanks but nope but you can find pretty much everything i build on www.rcgroups.com if you search for meatbomber
  7. yaniv
    yaniv Active Member
    this model look realy like a real bird
    i also a part of the rcgruop
    and tray lots of time to make my paper model into rc model but never find how to do it :(
    thank u for sharing us with your great work
  8. yaniv
    yaniv Active Member
