1:33 Fokker EIII
Discussion in 'Internet Finds' started by Ron, Feb 14, 2004.
  1. Ron
    Ron Member
    Lech of modele-kartonowe.com has just added a beautiful free 1:33
    Fokker EIII to his downloads. Visit http://www.modele-kartonowe.com
    to see his kits
    I'll see about doing a step by step on this one!
  2. RichBohlman
    RichBohlman Railroad Card Modaler
    Just printed the Fokker EIII - very nice model :D
  3. Gil
    Gil Active Member
    Had to screw around with refilling printer ink...., even had to resort to loosening up the dried yellow with a little alcohol. Very nice model of the EIII. Now have to find time to build it..., the wing construction technique is intriguing as is the propeller and the layered cylinders. Should make a fine looking model when fully rigged.
    A very heartfelt thanks to Lech for his kindness.
    Best regards, Gil
  4. Ron
    Ron Member
    Just got to building the framework today...If you start this one up, make sure your former material is just under a mm in thickness. So far everything that doesn't depend on thickness fits like a glove. Having had to make adjustments due to the artist's board I'm using, I'm saying a small prayer that all will be well :)
    I'll post a pic in awhile. Yeah Gil, this model *is* intriguing! Raimund, this one is right up your alley. Rigging tips from the master? (hint, hint)
  5. rkelterer
    rkelterer Member
    ron, you are strirring in open wounds :wink: i loaded up work, do not ask me, much work, but still thinking how to realize a rigging tutorial.
  6. Ron
    Ron Member
    Raimund, I know you're a busy guy :) Anyways, so far, so good.
    I'm moving this one over into the Aircraft forum for anyone who's interested.
