1/144 scale Yamato
Discussion in 'Everything else' started by Bowdenja, Aug 4, 2006.
  1. Bowdenja
    Bowdenja Active Member
  2. That foam technique can be used in paper. By filling the voids between the framing with pink/blue foam and wire cutting and sanding. But one has to be careful as if sanding by hand as you can wid up with hills and valleys with the frames being the hills. Makes for an incredibly strong and light hull.
