Having a run at the Legal01 Re-envisioned Saturn V Mark III
9,549
I believe that is true. A machine will not run itself, it takes a master machinist. Wood will just lay there, till a master carpenter comes along and makes something out of it. On a fishing ship, the captain, master of his craft, keeping logs that represent years of places that fish have been congregating. Even the guy who baits the hooks, the "masturb.............well, maybe he's just the guy who puts the bait on the hooks in a professional matter.:wink:
bgt01
Exemplary Confidant
Jan 26, 2012
576
843
93
Ohio
This is really looking great. You are doing a fantastic job. I've got a special interest in your build because I'm building my own version of the Mark IX Hawk from Space: 1999 and guess what kind of rocket the engines come from...:wink:
Reactions: SonOfAGun2501
SonOfAGun2501
Esteemed Member Extroadinaire
May 11, 2014
324
642
83
45
Ichikawadaimon, Japan
In the future when making this model, be careful of the following...of course if this kind of think doesn't bother you then don't worry about it.
There are some gaps when placing the thrust chamber together. to avoid this just measure your strips down and cut appropriately. That should leave a fairly seamless join.
Reactions: zathros and bgt01
SonOfAGun2501
May 11, 2014
324
642
83
45
This next piece is one I have had problems with in the past and just not sure if I am doing it wrong but I came up with a sort of fix on the fly. It's not 100%, but what is these days? In the instructions, it's very vague on this so if anyone else has had a similar problem try this. Basically, when assembling parts 25,26,27 the end result is too tall.They give spacers for part 25 which is 25A but it is precisely part 25 that is making it too tall and I need more part 17 (to be added later to level these bad boys out ;) ) So, I cut a hole in the top fold or part 27 and I cut a hole out of part 25 then insert the rounded part 26 into this. It does make it lower but not enough yet. I suppose I could completely cut a hole through part 27 but then you would lose some of the detail visibility of 26 and 25. So, with less rambling, here is how I did it.
20150720_195425.jpg this is the gap. Didn't photograph as well as I'd hoped.
20150720_191313.jpg 20150720_191910.jpg 20150720_191943.jpg This is a better shot of the distance gap.
20150720_192615.jpg 20150720_192957.jpg 20150720_193421.jpg 20150720_195425.jpg 20150720_194100.jpg 20150720_194417.jpg 20150720_194433.jpg
