ARMORMAN's WARHAMMER 40K Models Thread
DaveyBoy
Thanks, I found the "picture" of the pdf, but there is no download link to go along with it though.
Many Thanks for the link.
Dave.
t.l.williamsjr
Dave:
When you get to the page with the pictures, click on the picture of the one you want to download. A larger picture of the item will be displayed with some info on it. At the bottom right of the larger picture page you should see a redirect html link that will send you to a download of the desired page stored as a PDF file which should start downloading to your screen. At the tope of the displayed PDF you should find a downward pointing arrow over a horizontal line, this is a download command to download the pdf file. Click on it and you should get a popup asking where to store the file. From there on out it's all yours.
TomW
Dave.
ARMORMAN
FOUNDATION CORNERSTONE
Click on the picture, it bigifys, underneath it is a link to the file....
I posted this earlier, but forgot to post....brother....
DaveyBoy
Dave,
Did you try the links at the above posted vk.com link?...They're all there and working.
Hi, Thanks for getting back to me, Yes I did check over on vk.com and although there are pdf's with those titles they are not the one's that you posted (now non-working) links for.
Thanks for the advice.
Dave.
DaveyBoy
Links worked fine for me
If you're getting a download off the 2 links (I'm only guessing your reply was to me ?) then you are getting something I'm not, all I get is a countdown from 25 then a message telling me that the file has been taken down.
Best Wishes,
Dave.
Best Wishes,
Dave.
The reply was to either of you.....Not sure why it didnt work for you, when I click the links it opens the pdf's directly, and i save them that way
