Ninjatoe's Mk-II Viper
starbuck
898
1,825
93
Austria - Carinthia
Glad to see your process in your Viper - it looks great.
I did this model too. It was my first one and you can imagine how it turned out. Based von your pictures I would say that also the Viper oft UHU will be a model you should be able to build. It is worth doing.
blake7
719
949
Mannington wv.
Thank you Starbuck. Maybe when I get more ink and paper Iwill try UHUo2's viper. Right now working on the stack of papercraft I have already printed out.
blake7
719
949
Mannington wv.
Ok I finally got back on doing the viper. I made the base next, so that I could put the model on it while I put the parts together. I then started doing both engines at the same time, but I only made it this far. I did use a red marker for the tip of the viper, and a black one for the tip of the rear engines. I will post more as I do more.
blake7
719
949
Mannington wv.
And here are the guns, which finishes the model. By the way any body got a enlarger/shrink ray gun which would make this easier. I know Rhaven Blaack must since all his detailed Thunder fighters look so good:rolleyes:. Next time can I borrow it:D. I want to take some outside pictures of the model so it can be seen in better lighting.
9,550
Very nice! Watch those cigarettes, Tyllium s very explosive, and the smoke messes up the gauges!! :)
blake7
719
949
Mannington wv.
dnalor thank you, and this model has been sitting already printed waiting for me to build it for two years. Zathros I notice I accidently took a picture of my bad habbit. sorry. Thank for not giving me the lecture about the ills of smoking:cigar:.;):)
12,334
Excellent build, blake! As I recall there are not many build threads on this model out there. In fact, yours might be the third or fourth I have ever seen (NJ was the first, then came Loenf's build...). :)
9,852
View attachment 135760 View attachment 135761 View attachment 135762 View attachment 135763 View attachment 135764 View attachment 135765 View attachment 135766
I am sorry, but I do not have an enlarger/shrink ray gun. When you are able to make it, you can use my build threads as a guild.
You did a GREAT JOB on this model!!!
I am looking forward to seeing your next project.
KEEP UP THE GREAT WORK!!!
9,550
That picture looks great in black and white, see below. :)
