Detailed Thunder Fighter Project
9,857
Parts 104 & 142 are glue strips that need to be put on (the top of) parts, 206 & 211 so that you can attach parts 67 & 105 (after you have assembled parts 67-87 & 105-127 into their respectable sum-assemblies)
9,857
Unfortunately, the pictures do not show it, but it is a glue strip that helps hole parts 206 & 211 to parts 67 & 105.
The flat side is attached to the (inside) top of 206 & 211. The toothed side is what holds (the bottom) parts 67 & 105 to parts 206 & 211.
12,338
If you take a close look at the parts pages you will see that Martin has sort of grouped the parts. The layout tells you which parts belong together. Follow the shape of the parts to see which end goes where. All untextured parts are either formers or (if they have teeth ;) ) glue tabs. Using separate parts as glue tabs makes the finished product look much smoother and cleaner.
9,857
This is a small update.
I have attached the cockpit interior to the upper skin.
The upper skin is attached to the main body of the plane.
The main console is now in place.
Now to work in the rear end and add greebles!!!
Please stay tuned to your local Earth Directorate Broadcasting channels for further updates as they happen.
Thank you for watching.
micahrogers
3,773
4,643
Shannon GA
Is the basic thunderfighter in the resource section? if so in what section? I lost all the plans I had when my last puter died.
9,857
9,551
Get them all! Things have a way of disappearing! :)
9,857
Here are the exhausts. I added all of the detail that I could and made them as close to screen accurate as possible.
The Exhausts are now attached!
Now on to the landing gear and wings.
9,857
Here is another update. I have attached the landing gear bay doors and added the same brackets that I used on my last TF build.
I attached the main landing gear.
I attached the lower wings.
I attached the main wings.
Now onto the sponson cones and the canopy.
