cutting models
Where do you cut?
  • Total voters
    104
xBobble
27
7
3
:wink:
It's an investment, but if you can REALLY improve cutting...
I guess it depends on how bad you were in the first place. :wink: The Cameo does have a bit of an issue with very, very tight angles. I think the problem is that, while the cutting point is very small, it's still the tip of a strait blade. That blade sometimes has a little bit of a problem making very sharp turns -- going one way, pivoting, and going back the other way. I think there are ways to get around this but I've never had a big enough problem or needed a perfect enough cut to investigate them.
Anyway, full disclosure .....
jean-lucpicard
10
United States
I have to agree. The lines are simply a guide for where to cut a majority of the time. There are times though when it is really necessary to follow them, but I have found that this is rare - most kits leave room for discretion when cutting.
