Farnsworth communication device from Warehouse 13
12,350
Maybe we could add a Flower Power Farnsworth to the collection, too...:mrgreen:
9,891
I can see Claudia jumping for JOY.
Or some nice pastels for the "Miami Vice" '80s Farnsworth:thumb:
Myka & Leena is going "Glassy eyed" for the pastels.
how about a camo pattern? wait, then you won't be able to find it. never mind, carry on.
And Pete say "OOOHHHHH CAMO!!!!!"
Then there is poor Artie sitting at his desk shaking his head :cry:, saying "Why can we not keep it simple, people?".
Last but not least, Mrs, Fredricks telling Artie, just let it go and take care of the next case.:whip:
12,350
BLACK. With a red running light on top. And when you open it, it says, "Hello, Michael!" :mrgreen: :p :rolleyes:
12,350
Hi, folks!
I have finished the revision of the texture. This is the final look. I'll be testing the knobs and will pass everything on to b0bman for a last check. I hope you like it! :wave:
johanvanacker
140
38
33
Belgium
I started watching the series Warehouse 13 out of curiosity due to this post.
After a few episodes, I'm already hooked on to it.
12,350
It was a joy to see Saul Rubinek again when the show started. I remembered him from ST: TNG where he played Kivas Fajo. And I liked the crossovers with Eureka.
12,350
I've updated my alpha build by printing the blue texture on regular thin paper and glueing it to the casing. It looks much cleaner now. The edges still have to be painted. I feared that the blue was a bit too dark but when I looked at it again this morning I was really pleased with the result.
I also added the rivets to the holes. They were laminated to 1 mm cardboard. I used a rod to align them.
12,350
Now on to the knobs. The front plate is laminated to 1 mm card. Four holes are cut out. Two textured plates are glued to the back to close two of the holes. Then the back plate is attached.
12,350
The two lights are pre-shaped with a rod and edge-glued together. Several detail pieces are laminated to 1 - 2 mm cardboard and attached.
12,350
Knob #1 is assembled.
12,350
Knob #2 finished. This one is a bit tricky because of the funky foldings; so we have another "Revell-Fan moment" here again! :mrgreen:
12,350
The edges are painted and a back part is assembled. I copied the same strategy I used for Crichton's joints.
The knobs are put through the holes in the front plate and glued to the back parts. The knobs are held in place and rotate nicely.
12,350
I'm thinking of releasing a white pattern which can be used for printing on metallic (brass) paper (front and back plates and hinges) and textured / leather paper (casing skin). So you may build your individual FW (feat. pastel colours, camo pattern and Flower Power action!) ;-)
12,350
Now that the front plate is complete I continue with the lens and the internal structure.
It is best to cut off the flaps of the lens and glue it together from the backside with paper strips. Then it is attached to a flat cylinder.
Having joined the two parts I noticed that it would be wise to add some formers. I updated the parts pages accordingly.
12,350
Some of you may argue that the lens should be removable. However, I fear that this would cause some trouble since the front plate is detachable. The lens would not stay in place. If you find a way to make it detachable and stable at the same time, feel free to post your idea here. ;-)
EDIT: I've just come up with a possible solution which has to be tested. I'll keep you posted on this! :thumb:
12,350
And here are the last parts for today. They are attached one step at a time. Attaching them was a bit tricky because it was somewhat difficult to work with them as soon as the glue was applied. I was unable to hold them without covering my fingers with glue. I thought about that and changed my strategy. Instead of applying glue to two faces of the part I put it on only one face of the part and on the base. This worked much better.
A pair of toothpicks assisted in aligning the holes for the antenna.
