More skin!!!
Here is an update on the skinning of this project.
I do have to say that I have made a HUGE NOOB mistake when making this model in 1:50 scale. wall1wall1wall1
I used 200gsm card-stock (which is what I had on-hand at the time). UHU02 said to use 160gsm card-stock. Because of such, I have ran into a few fitting issues (as you will see in the photos).
(*NOTE* I will finish this build out, but I will be displaying it with the skins off in the diorama.)
Here are the parts of the nose skin.
Then nose skin is assembled.
The nose skin is in place. As you can see, there is a bit of a gap (this is caused by the thicker card that I am using).
Here are the parts for the lower engine section cowling.
Lower engine cowling assembled
Lower engine cowling in place. As you can see there are caps here as well.
The moral of this story is, If you are suppose to use a certain weight (or thickness) of card-stock for a particular model, DO SO. Otherwise, you will wind up with a model like this.
