The UHU02 Colonial Viper appreciation thread
Rogerio Silva
What do you mean?
Guys
If I understood it correctly, you guys are debating about whether the side panels of the cockpit should be glued to the "skin" or the inner structure, is that right? If that is the case, then a pic from the MASTER"s site should end that doubt:
http://uhu02.way-nifty.com/photos/uncategorized/2013/08/08/d2.jpg
Sorry, it says the remote file is too large.:cry:
Do you see the panels attached to the inner structure (formers)?
I hope this helps! :confused:
mcusanelli
You guys are doing an incredible job on this model, a fact I appreciate more now that I printed it out.....Man, it's small! I think that when I actually get time to build it, I'll probably build it landing gear up, with a pilot in the cocpit, nice and simple for the first attempt. Then I'll get it printed out much larger, 'cause I can tell you my bananna fingers aren't gonna be able to handle the small interior parts! I'll do the same with Uhu's UFO Interceptor too. It's really inspirational to see this stuff being built so beautifully, great thread!
Mike
Guys
Just thought I would embed the photo for you. :)
Guys
Since I have noticed some fitting issues myself (which mainly COULD have been caused by the fact that I haven't cut the slits into the formers wide enough) I believe there will be some difficulties in everyone's build. We use the same plans but we don't use the same paper like the master did, and depending on accuracy of our assembly there will be some (minor) individual adaptations necessary here and there. The positive aspect of this is that every one will end up with his own personal model.
Mike
Thank you very much! :thumb:
Unfortunately my allergy is troubling me again :curse: . I have therefore switched to a project which requires no glue, meaning the unfolding and texturing of the New BSG hangar bay. I'm preparing the whole repair bay in scale with UHU's Viper. I still need to make the floor and the hangar walls behind the catwalk. I hope that everything is better next week so that I can continue with the Viper.
LET ME ONCE AGAIN THANK YOU ALL FOR JOINING THIS GROUP BUILD; YOU ARE DOING A GREAT JOB, GUYS! :thumb::thumb::thumb:
silveroxide
silveroxides Viper
The way that is pictured in the undressed version above, is probably how I am going to display it. It will either have a two section wall hangar diorama or displayed on a hangar deck floor
Here is how I made my oxygen canisters. This procedure will work with the smaller parts too Keep in mind, that the wrapping tool, should be smaller in diameter than the piece being made The wrapping will give the part structural strength. The top cap or the oxygen dispenser cap has a thin laminated edge which helps in adhesion of the parts edge stripping. Enjoy and hope to see some more of the other builds:thumb:
Here are the components for the last engine bulkhead and after burner.
Components assembled.
Components attached.
Components that go on either side, between the the upper and lower engines.
components attached.
Here are the parts for the engine exhausts.
I decided to go with the black exhaust disks, because, once this Viper is finished, it will be in either a "Repair" or "Overhaul" state.
I used glue strips to help reinforce the edge glued seams.
Exhausts are assembled
Exhausts are attached.
Please stay tuned to your local Colonial Broadcasting Service Network for further updates as they come in.
Oh, man, how can I join a group of GIANTS, being so small...?
You are not that small (even though I am 2 meters tall (6' 6" if you are in the US).sign1
Just print the model out and start building and start posting!!!:thumb::thumb:
It is that simple. If you can tackle UHU02's Enterprise, you can build this Viper! :thumb::thumb:
I have confidence in your abilities!!!:thumb::thumb:
NOW START BUILDING!!!
announce1 SO SAY WE ALL! :wave:
silveroxide
The build starts with one step at a time, before you know it, you are running and it wont be too long before you are flying.
I noticed in all the builds, to include my own and even UHU, the viper wants to droop at the front. In the next attempt, I believe that if you build the frame work bottom first, it will make the top fall in place and any trimming necessary could be done to the top and keep the pressure off the framework. especially the front piece bulkhead.
Rogerio Silva
All right, all right...
Guys
Please, I have to explain that I couldn't find the paper in the grammature I needed (170gsm). :cry: Fortunately, I discovered a nearby paper distributor that delivers, so I've bought papers in 170 and 230 gsm, in both A4 AND A3 sizes. :mrgreen: :thumb: :cool:
Should I try to follow RF's steps and upscale it in order to print it in A3, I guess I'll be able to do it. The problem was my printer, that repeatedly refused to pull the paper sheets I had, because of a mechanical problem. Problem solved, I bought a new printer, and this time it's a Brother A3 multifunctional. :twisted: If that doesn't print, then I'll give up (naaaah... :rolleyes:).
Not that I'm giving excuses, but I'm building three models (you can check the threads and drop a PM to RF), and I'm also between houses. It's a total mess, but I've been trying to keep it up. :eek:ops:
Nevertheless, when RF invited me to this group, I enthusiastically accepted, and I should not be the one to drop this ball. So, I'll take the papers home (they delivered it to my workplace), and start working, but let me warn you: it'll be in a rather small pace, ok? :eek:
All the best,
Rogério
vbsargent
And here are the pics that I have so far of my approximately 1:72 scale build. I was guestimating that the ejection seat would be roughly 18" wide so I printed it at 61%. I used an HP desktop printer and 61# card stock.
521a87f3-e5b2-42ce-a320-c04fc44cb5b2_zps187e9814.jpg~original
By the looks of that pry bar, it appears that our new crew chief is spoiling for some toaster trouble as he inspects the new bird.
DSC09845_zps41d0e33c.jpg~original
DSC09842_zps6d9e45d1.jpg~original
DSC09848_zpsfc504e0c.jpg~original
Chief wasn't paying attention, they installed the forward cockpit bulkhead backwards! I think that he missed that snaffu due to a little too much fuel grade alcohol the night before.
DSC09841_zps4d4e80f9.jpg~original
DSC09849_zpscf624da3.jpg~original
DSC09851_zps28e596fa.jpg~original
DSC09840_zps99e39bb5.jpg~original
DSC09858_zps01816beb.jpg~original
Tiny TINY pieces!
DSC09860_zps8349f809.jpg~original
DSC09864_zps3544b51f.jpg~original
Hmm . . . I notice Chief is missing in action. Must be playing a hand with Starbuck.
DSC09863_zpsf849a0d6.jpg~original
DSC09868_zps57685195.jpg~original
DSC09867_zpse59082ec.jpg~original
6002f738-7ed6-4527-8087-267ee6d43024_zpsaf4d78cb.jpg~original
that's it for now from the depths of Galactica Skunkworks. Hopefully Chief will be back next time to make sure everything is done the right way first time around.
Rogerio Silva
vbsargent
Now that's a challenge! I've been gathering all the courage I have to build this thing in the scale it was made, and maybe ease my life by rescaling it to fit an A3, and you downscale it even more? This thread was fantastic, now I won't miss this for the world!
GREAT JOB!!!
Rogerio Silva
Say what you mean, mean what you say.
Fellas
I wrote I was going to take my paper home and print the Viper, didn't I? Well, here it is, as you can all see in the pic. I keep my promises. :thumb: :mrgreen:
Now, I'll start the build tomorrow :eek:ops:, and start being an active part of this group (AT LAST!!! :rolleyes:).
Rogério
