Battlestar Galactica 1.5'
Status
9,855
Here is the bottom part of the Bridge section.
Here are the formers.
The skin wrapped around the formers
Adding the ribs for the armored hull plating.
Ribs are painted
Adding Armored Hull Plating.
kevlary
Lincolnshire
Its looking good that is , im loving the detail , you've crammed into it so far, i could just do with one of those in my bedroom ceiling:thumb:
9,855
Thank you one and all for the kind words, encouragement, and support on this project.
For now, I am putting this project on hold. I recently received the plans for Ranger-3 from ThunderChild to test build. I have started a build thread, which can be found here: http://www.zealot.com/forum/showthread.php?p=969972#post969972.
Once I have finished the test build for Ranger-3, I will return to this project.
9,855
Back to the Galactica
After a successful (and enjoyable) test build of Ranger-3, I am now returning to this build once again. Here is my progress thus far.
I am continuing with the armor hull plating.
Here is a close-up of the armor hull plating.
And more Armor hull plating.
The sides are now covered.
Here is a close-up of the center section greebles.
The bottom part of the Bridge section is now finished.
Now it is time to tackle the middle section and the hanger pods (Before I can attach the bridge section parts together).
9,855
Update
Here is an update of my progress.
I have started on the middle section.
I will add the Armor Hull Plating after I have attached the sliding arms and the Landing Bay Pods.
I now need to work on the Landing Bay Pods and the sliding arms.
9,855
Thank you all for the kind words and encouragement.
Since UHU02's Viper has now been released, I have decided to put this project on hold for now, until I have finished the Viper build.
Please do not panic or worry. I will finish this project.
sjsquirrel
541
22
18
British Columbia, Canada
stevebondy.ca
Greetings from Puerto Rico
I am a fan of Battlestar Galactica I just finish my Battlestar, And would like to start building the rest of the other ships,can anyone help me to locate them.
The ships are all available in the downloads section here at Zealot but you need to have 10 posts before you gain access to the downloads area. They are also available at my website.
Steve
9,855
Greetings Ladies and Gentlemen,
I know that it has been quite awhile (about seven (7) months) since my last post in this thread.
As promised though, I have resumed (albeit quite slow) work on this project once again.
Here are the photos of my progress thus far.
I have added the ribs to the main body.
I will be adding the armor hull plating later.
I started on the pylons for the landing bay pods.
I used superglue to re-enforce the brackets that help keep the arms in place when they slide in and out.
Hangar bay Pylon assemblies are finished.
Hangar bay Pylon assemblies are in place.
Please stay tuned to your local Colonial Broadcast System for further updates as they happen.
9,855
To all that were following this thread, I am sorry, but this was one of the models that was left in Eastern Europe when I returned to the US.
Unfortunately, this is a dead project. Yes, I do intend to rebuild this model, eventually.
I am closing this thread. permanently.
Reactions: Revell-Fan
Status
