I started working on a 1/48 Supermarine Walrus (by Ladndad) and decided it needed a more detailed engine, Here are a few pics of the prototype I am working on and the dxf file that I built it from(mostly, it has gone through a number of revisions).
I have only fully completed 1 cylinder so far . it took a while to get a valve cover design that I could build and looked half right, it only has 2 valves instead of the proper 4 and no exhaust pipes currently, though there are some in the plan I couldn't roll them tight enough on the 32Lb bond (120 g/m^2) paper that I am using.
Ill try to clean up the dxf file and produce a pdf soon
FWIW I used QCAD to create the dxf it is 1"=1" and printed at 1/48 scale
