Spartacus
Hello All
This is my first ever build, kind-of. I started on the small Mass Effect 2 Normandy SR2 Cerberus, but it started getting fiddly quickly so I've put that to one side to get a simpler model done, learn the ropes & get the confidence up.
An experienced modeller could have done this in a couple of hours, but I've been spreading it over a couple of nights, hour here and there.
I've found the UHU glue I had laying around is a bit tricky. Dries very fast, which is nice, but goes tacky so quickly can leave "spider strands", some of which have hit the model (many - not all - of which I've got rid of with the needle-nosed tweezers). Might look at getting some basic "school white" glue. Probably a lot more novice-friendly.
I must have set the PDF print wrong. The wing sheets didn't quite print out (and I'm too cheap to re-print on this test model). If you look at the black cut-out wing notice the top-edge which should be grey is white, along with the tips on the left (it's not camera flash glare). Those are literally the edges of the paper. You can see the un-cut wing overlay is missing it's edge on the bottom too. I'm just going to cut at the colour's edge on that one, the wing it goes on has a fully coloured edge.
Anyway, more cutting out to do of solar panels and wing struts...
L8rz
L8rz
