Building Uhu02's Enterprise
Rogerio Silva
1,520
11
38
56
Rio de Janeiro - BRAZIL !!!
Welcome, ShadowHawk!
Wow Rogerio I think it's looking real good.
When I see your pictures I get this urge to build this magnificent model myself but I just have to restrain myself not to go to fast to soon.
You mention that you build this without the Tabs, are tabs those little glue flaps on each part ? and if so how do you glue the parts together then ?
I can see you get a more even result without tabs because of the thickness of the tabs raising the part that you attach. Do you use custom strips (tabs) at the back for glueing the parts together so you can slide the edges of the parts neetly together ?
Anyway, your Enterprise is starting to look great :thumb:
Hey, ShadowHawk
Look at me, a newbie giving out advice...sign1 It's always good to hear from you, buddy! Did I mention I know your beautiful country?:mrgreen:
About the tabs, yes, they're exactly what you've wirtten. Not using them increases significantly the quality of the model, but also the difficulty of building it as well, unfortunately.
What do I do? Butt-joining, which consists of glueing the edges and holding them together until the glue holds. In places where I think the tension on the paper will be higher, I also apply some tape, but I did apply some "back tabs" (what you called "costum strips"). I have used all three techniques and combinations of them as well).
You can find tutorials about this right here in Zealot (why bother to look somewhere else?).
Rogerio Silva
1,520
11
38
56
Mentor
Well (like you said), So far, so good. You are doing a GOOD job on this model. That is the GREAT thing about this hobby, you can pretty much do whatever you want to make things work and if you make a mistake, it is easy to fix (either with just a simple piece of paper, printing new parts to fix the broken ones).
the good thing about this model, is that there is room for making formers to add support to areas like the one you had problems with.
Keep up the good work.
Mentor,
Thanks for the kind words, Rhaven, I try to follow your steps. And Zathro's! I got this idea of not using tabs from him, and read some posts about it. Your encouragement has given me confidence to keep going.
Thanks a lot!
micahrogers
3,772
4,639
Shannon GA
Are you reinforcing some joints with tape? joining with tape? I'm intrigued.
9,888
Good morning and nice Saturday!
Here in Rio it's warm and cloudy, what increases the warmth! I started to work on the lower part of the saucer... This is where things gone terribly wrong in the first time, so CROSS YOUR FINGERS AND HOLD YOUR BREATHS!sign1
Here are some before-and-after pictures. I had to butt-join the two pieces, and did not tape it.
It sounds obvious, but the best way I found to do this is by sectors of 30-70 degrees, one at a time. Check it out.
When you have parts like this (or thin flat discs that are about 1-2 mm thick), you can laminate the disc to the thickness that you need and wrap the edge skin around it.
this will save you from quite a few headaches
Rogerio Silva
1,520
11
38
56
Hurrah!
HURRAH! HURRAH!
I was able to apply the formers and there was deformation, but I think it's non-significant.:mrgreen::mrgreen::thumb: IMHO, it's within acceptable range, so it's a GO for keep on building!:mrgreen::cool:
Check the pics. Formers were fixed using double-faced tape, except for the smaller one, that was glued.
Rogerio Silva
1,520
11
38
56
Going on...
Hi!
Well this is hardly a tribute to UHU02 :inw:, but it's the best I can do and offer. I manage to go past the point where I failed on the first time, and I think that (one of) the hard part(s) is gone. Now for the pics...
Yeah, yeah, I know... a bit skewed... But still in tolerance range:mrgreen: You have to bear with me, I'm a newbie, assembling a UHU02 :inw: model, using butt-join for the first time! It's a good work... for me!:twisted:
micahrogers
3,772
4,639
Shannon GA
Looks good so far Rogerio. keep up the good work and thanks for all the pics.
:thumb:
ShadowHawk141
167
Netherlands
That looks pretty dandy Rogerio.
I don't even dare to start this model yet and you do this without tabs !!
I've posted some new pics in my Venator thread but things aren't going so well on my side....
Cheers and keep up the good work, you're doing a great job !!
Elko
Rogerio Silva
1,520
11
38
56
:thumb:
Thanks, micah! Kind words of a giant in the art!
You're one of the guys that make me want to go on with this.
Elko
Hey, ShadowHawk!
I've told you once, and I'll tell you again: if I can do it, EVERYBODY CAN! I'm no artist, I have no great skills, but I believe in one thing they teach us in the Navy: chance favors the bold!
Of course, if you can have the support you've got here in Zealot, things are A LOT easier and smoother. For instance, I would NEVER EVER, EVER had thought of assembling a model without tabs. Well, I would never ever even think of building models again, if it weren't for papercraft!
But I've got to admit: once I saw the paper models people were doing, I though this couldn't be possible, and so I decided to give a try in the fantastic 1966 Batmobile model by none other than the great BRAZILIAN (YEAH!!!) Claudio Dias. It was difficult, but DIFFICULT IS NOT IMPOSSIBLE!
You can do it. WE ALL can do it. GET TO IT AND MAKE IT HAPPEN, my friend, you can AND WILL do it!
If my Enterprise is not the way I wanted it to be, well, it's still within tolerance range, so it's green light all the way, man. Go FOR IT!
Rogério
P.S. Have you ever seen "Back to the Future" (who hasn't...)? "If you put your mind to it, you can accomplish anything". Marty McFly, 1955.:thumb:
Rogerio Silva
1,520
11
38
56
Started the body
Hi
I started the body, according to the instructions. A little advice: take a look at Uhu02's site. It's very insightful!
In order to put together piece #36, a combination of butt-join and tape had to be used, because of the paper tension. I think I managed, but it could look a lot better, although still within tolerance.
Here are the pics.
ShadowHawk141
167
Netherlands
That body part looks nice and crisp, I can see the advantage in not using gluetabs.
I'l stick to using gluetabs for now though untill my skills are up to par.
It's good to see you make this model Rogerio, I like this model a lot and you're showing a fine way of how it can be done, a nice presentation and instruction of the model itself.
Cheers,
Elko
Rogerio Silva
1,520
11
38
56
Now that you've got me started...
Howdy!
Making this model has been quite an ordeal, for I'm not as half as skilled as many people here. But as much as it has been very hard, because of the choices I've made (an amazing model, and no tabs), it has also been very accomplishing.
As a newbie, nothing gives me more pleasure in this hobby than to make it happen, and to give my small contribution by sharing my experiences, and learning a lot from the "big guys".:cool:
Anyway, this model does deserve a special place and care in all of our "heart shelves", because it was made by the GREAT UHU02, and it is STAR TREK. Enterprise is, if not the one by excellence, one of the most iconic starships in the Sci-Fi culture.
And UHU02 just did it. Again. This model is beautiful, the curves are just right, everything is so darn good about it, that it just doesn't matter being hard. It only matters that each piece I assemble within (my) tolerance brings my dream of having this Enterprise closer.
In conclusion, maybe it's not an ordeal at all, but the steps to get something I want pretty bad. And you know what? The harder it is, the more value I'll give to it when it's finished. And the pride to say "I did it!", even being an unskilled newbie, but I did not give up!
AND IT'S UHU02,:inw:!!!! the man that creates astounding models and gives them away for free, just for the love of his art!
All the best,
Rogério
P.S. Maybe the last part of this post should be in the UHU02 appreciation thread...:mrgreen::mrgreen::mrgreen:
Rogerio Silva
1,520
11
38
56
If you're happy, I'm happy
Cheers,
Elko
GREEEEAAAAT ShadowHawk!
Man, I started with the tabs, and I absolutely do not regret it. The thing is, I started a thread about using (or not) tabs. And the general consensus is that tabs "should be eliminated, kill them, kill them all!"sign1, and that's why I have decided not to use them.
But I don't have an extensive list of assembled models to back me up here, just the ones you've seen in the other thread (Iron Man's). I just knew that this path was going to be taken someday, and I felt I shoud do it ASAP.
I think we all are perfeccionists (how can you not be in this art?), we just need to calibrate the level of our tolerance, otherwise we won't achieve anything. EVER.
So, when you feel you're up to it, just do it. I'm sure you'll be able to make this happen, but don't forget the essence of this: HAVE FUN!:mrgreen::thumb:
Cheers,
Rogério
Rogerio Silva
1,520
11
38
56
Going on...
Hello,
Working on the body is no walk in the park, but things are going nice. The first pic shows the deflector and front body part ready. The second one shows the rear body former, and I'm in doubt about how to assemble pieces #6 and #10, but I think I've got it. I'll try soon enough.
The second pic also shows the beginning of the hangar bay door assembly. I'll soon finish that. Take a look, please!:mrgreen:
Rogerio Silva
1,520
11
38
56
Hangar doors
Here you can see the hangar doors (and entrance) in place. It's a bit harder without tabs, but the results surely compensate for it.
Just to make it clear, tabs have been used only in the formers.
