Mocking Jay Pin (Hunger Games)
sjsquirrel
541
22
18
British Columbia, Canada
stevebondy.ca
Hi everyone. A while back I saw The Hunger Games and got poking around on the net for pictures. I ran across images of the mocking jay pin the main character wore and whipped up a couple versions. This is version 2. Both are available on my website (see my signature) along with a little more history.
The photos don't do it justice. It looks much better in person.
picture.php
Construction is simple. You just cut out the pieces and glue the layers one on top of the other.
picture.php
I chose to cut off the pendant ring as I wasn't going to use it anyway.
picture.php
picture.php
The base seemed a bit thin so I glued a few extra layers of card stock to it.
picture.php
Here I'm gluing up the bird layers
picture.php
This is the first 5 or 6 layers I think. I used my little scoring tool to trace some of the lines in the pattern giving it a more 3D look and feel. I also use the little ball on the tool to rub the edges of the layers, smoothing them out a bit.
picture.php
Ready for the last few detail layers.
picture.php
Detail layers cut out and ready to glue
picture.php
After gluing all layers I used a small knitting (crochet?) needle to rub the edges all around and smooth it out. The circular base got the same treatment. It's subtle, but it really adds to the finished appearance.
picture.php
Almost done
picture.php
And done
picture.php
And finally, a comparison to the original pendant I used as the template. A good reproduction I think.
picture.php
One day soon I'll make another and color it with a good metallic sharpie or something like that. Should make it look awesome.
Enjoy!
Steve
sjsquirrel
541
22
18
stevebondy.ca
Thanks
Thanks guys. I'm very pleased with how they turned out. After finally getting around to doing this post I felt motivated to print out a couple more (the patterns print the parts for two pins per page) and I'll build them and paint them to see how they look.
I'll post a pic when it's done. I only have 4 or 5 build projects going, so how long can it take? :mrgreen:
Cheers,
Steve
You think you could design a "Zealot" pendant? That would be so cool!! :)
sjsquirrel
541
22
18
stevebondy.ca
Well, I'm not so good at designing things from scratch, but give me a design and I can make it a kit.
Beautiful! Instead of the sharpie, you can consider printing it directly on silver (or golden) paper...
That's true. Silver and gold papers are hard to come by in my neck of the woods, but I do have some. Personally though, I like the idea of a more DIY, hand made, hand painted piece. I'll probably leave it to others to experiment with different papers.
Steve
sjsquirrel
541
22
18
stevebondy.ca
Not very good at designing things. I wonder?:confused:
You know what I mean. I didn't design the pin, I took someone else's design and made a reproduction in paper. Virtually all of the work I do in paper is like that. I build others designs, I take others 3D work and convert it to a paper kit, or take an existing kit and improve it, and so on. But I always start with a base from someone else. When it comes to designing an original piece, I'm not very good.
Steve
