Storm Talon
silveroxide
Now, if you look at the trailing edge of each wing, and you could still do this to our model, it looks like a long sideways "S" shape. This is because as you approach the center of rotation the speed relative to the air slows, so as the blade makes it's way inwards towards the main shaft from the tip, the trailing edge starts to drop, changing the angle of incidence of the wing cutting more steeply into the wind and securing lift at all speeds, while the leading edge looks pretty much the same. this is very pronounced on Blackhawk helicopters.
If you have a good eye, and know what you are looking for, you can see it quite clearly in this picture.
Thanks for the technical help. Yes I see and understand the aerodynamics of the blades. I added the extra extended edge (Aileron) at the end of the blade to compensate for the lift, but I forgot to make that angled end which is also used to compensate for the lack of lift at the tip. But regardless, the mechanic spirit of the Imperium assured that the machine will fly by having faith in the Omisiah Mehanicus.:wave:
This is turning into a BEAUTIFUL piece of machinery.
The deatil that you are putting into it, really brings it to life.
silveroxide
Attack Support Chopper
You are a Bastion of knowledge! :)
Thanks for your support Zathros. When I build a model, I usually try to make it seem viable, even if it is a make believe model.
I seem to be spending a lot of time in the details development for this version. It is almost done as a stock model and soon I will start with the weapons options.
Here are some more updates on the model. The details is what makes the model. Enjoy and see you all next posting.
Hey, I think AMORMAN is doing a double whammy! I resemble that remark!:p
silveroxide
It humbles me to think that some one thinks I am smart. I just think of it as having common sense.:cool:
Here some more update photos of the Heli, strech build.
silveroxide
Amazing and inspiring work here ! It's awesome :)
Thanks for the comment Lucius, I am glad that you have enjoyed the build threads.
And now, I am almost at the near completion of the Helicopter version. Here are some more photo updates on the Space Marine Chopper.
This really reminds me of building helicopter, visually that is. I like this model. You models are so awesome there no way I can say "I like this one the best", especially after your stage coach, buggies, chariots, but of this genre, I think this one is my favorite. I think because of the extrapolated in my mind, the rotors are too short, also, so you know, the reason they are bent back in the front is is to maximize the total area of lift as you said, and the bend back forms a delta wing of sorts. I attached a picture of what I thought would be a more balanced look, just for the heck of it. I lengthened the main rotor and the tail rotor blades. Your model stands fine the way it is, this was just some doodling around. I hope you don't mind. :)
silveroxide
My first idea for the rotors.as to make it long as you showed in the photo. The reason I did not go for the long blades, was because of the tail rotor. I Originally I was going to enclose the rear rotor in a ring like the Aloutte's, I do not think the enclosed and sleek look of the enclosed rotor would fit in the 40K universe, so I left it exposed. I could have lowered the rear rotor as well but the way I made it, it stood the chance of engaging the main rotor, which is the reason for the short blades. BTW, the elongated blades do look good
I think the BLackhawk Main rotor tips are like 2.8" inches away from the tail rotor tips!! They never hit though because when there is any lift applied the blades themselves lift so high they are way further apart. The Blackhawk Tail rotor is also tilted to help lift the tail end up. Like I wrote earlier, your model looks great and needs nothing. When I see models I like, I always end up comparing them to the real thing, in this case a real helicopter. Excellent job! :)
silveroxide
Knowing a bit about your aerospace background, I appreciate your comments on my builds. I still have a problem choosing which model I like best myself. As for the 40K universe, There are still many models to make, imagine or design.
The helicopter is supposed to have a chin mounted gatling as an option but then, those can be added later on. I think that I will leave it as is for now since I have to get on with something else outside the Sci Fi world, but I will be back to 40K again. I still have to finish that drop ship. Here are some more photos for your enjoyment and see you all at the ships forum after the next posting.:wave::wave::wave:
She's a beauty Silveroxide. It's just so pleasant to look at, form follows function. :)
silveroxide
In for a penny.....
I know! I know but I am not done yet, The fourth conversion will come soon, Before Christmas I hope. The in for a pound will come later.
Thanks Zathros, Here is the trio for now awaiting the fourth Musketeer.
Geez, I wouldn't mind having that on my mantle of coffee table to.... well let's be honest, play with! :)
The helicopter turned out beautiful. If I were still in the Army, I would have loved to have been dropped off at an infiltration site with one of these taking me there. or seeing one coming in to pick me up after a mission.
As for your trio, that is an AWSOME bit of fire power that you have.
I am looking forward to seeing the forth addition to this set.
