"V" Blaster
Hello Ladies and gentlemen ( as well as human eating Visitors).
Today I bring you the beta build of the "V" Blaster (designed and created by Revell-fan)
Here are the photos for your viewing pleasure:
8 pages of parts
This is the back side of the sliding (yes I said sliding) activator switch.
I placed black paper over the back so that you can not see through the open slits of the slide.
Close-up of the slide.
Showing the slide working
More close-ups showing the slide working.
Part of the component that goes on top of the handle.
Part of the front barrel assembly.
Part of the handle with formers.
Formers in place/
handle base finished
trigger guard in place.
Trigger in place.
top piece attached.
More photos coming soon.
Great work, RB! The idea for the slide cover is magnificent. I'd like to add this to the final plans if you don't mind.
To the fans: Just for you to know, RB is building the revised version with the accurized colour scheme. As soon as he has finished the build, the model will be released for everyone to enjoy.
Update
Here is an update on my progress of the "V" Blaster.
These are the side grip panels for the handle.
Side grip panels attached.
Mount for the center part of the barrel.
Mount for the center part of the barrel attached.
More rear barrel mount parts attached
Front barrel assembly.
Mussel assembly.
I am sorry for such a long break in this build, but I was on holiday.
I am back home now, so here is an update on my progress
This is the mid section part of the barrel. For those of you who are thinking about making this into a costume prop, you can make this part out of acrylic.
mid section of barrel attached.
Front handle/hand guard.
Front handle/hand guard attached.
This spacer plate can be made from 2mm card stock and edged black if you do not want to make the "box".
If you are wanting this to be sturdy, you can insert thin formers to help with rigidity
greebles attache.
connector attached.
Main part of build finished.
All I have to do is add all of the greebles and build the stand.
(Greebles first).
WOW! That's awesome! Can't wait to see the next pics. And thank you for your tips and insights! I'll put them to goo use.
Greebles, greebles, and more greebles
Here are all of the greebles that go on this model.
This is one of 14 ribs that go on the front guard.
First rib attached.
All rear ribs attached.
All front ribs attached. (I should attached all of the greebles to the front guard before attaching it to the rest of the model.
Detail on front mussel.
