I can try that, they taught me Russian long time ago (but it was the right age, because I still can read and understand (more or less) it.)... So first try here:
(I try to translate from top to bottom, from left to right)
1/55 - Upgrade of basic model kit of tank Leman Russ by Vadim "Patoroch"
2/55 - Aim of the presentation - To show possible upgrades to the standard tank model. In the first plan, the photodocumentation is oriented towards those, who build (or have built) the Leman Russ. But the material is for everybody who can feel the vibration of the paper body of a war machine and can hear the clang of the cardboard tracks
(wow, nearly poetry)
3/55 - Modernization of Leman Russ tank
Object of the work: Leman Russ Tank
Source materials: A set of details for the model
Developer of drawings: Patoroch
Construction materials: paper, cardboard, wood, plywood, foil, copper, aluminium and steel wire, polystyrene, opaque and clear plexiglass, various synthetic tissues, metalic and (?) meshes, imitation leather.
Used Glues: PVA (polyvinylacetate) for paper and cardboard, "Moment" a clear one for combination of materials, DCE (dichlorideethan (?)) for details from polystyrene.
4/55 Upgrade of the turret
5/55 1) Turret turning system
Problems: Open hatch and make space for a figure
Secure the gun barrel in the turret, eliminate its sagging
Provide fluent turning of the turret around its axis
Eliminate moving of the turret from its vertical.
To solve these problems it was necessary to change the system of the turret turning. (left is standart, right is new one). The small print inside means "turret turning axis".
Would this be enough? Sorry, neither of these languages is my native, so I need to dose it to myself in smaller amounts
In case someone is interested, I will continue this way
