help getting Transformers.War.For.Cybertron models
yperihitikos
27
Good news, everyone! I discovered a simple way to fix most 3dr format models. It's quick too. Here, take a look at this
Patience, guys. In four months Ill be free to work on the models all night and day long. I only have a few models with me.
In other news, I'm half-working on this
Could someone find the source of this, please? I was thinking about trying /m/ in 4chan, but my question would 404 before my next day out.
yperihitikos
27
Because of this new way to fix things, my work has been slowed down further, since I don't have the game here, and I don't want to release "imperfect" models. Not to mention that most of my free time goes to (much needed) shuteye. If you want to help me a little, then you could get a couple of things for me.
1) I need the models in the autobot war room from RotF. I suggest you capture a frame with 3d ripper in the begining of the campaign, where the entire war room can be seen. I remember there was a tutorial message showing on the screen.
2) I need Sideswipe from the Kaon mission in WFC. I suggest you take some other character and capture a frame when Sideswipe is relatively standing. For example, when you talk with the captured Air Raid.
Important! In both cases, I need the bots, a piece of the floor and the outermost bubble that contains the entire thing, in 3ds format. Thanks in advance.
Don't email me, since I rarely check it. Better pm me.
yperihitikos
27
nav
175
It looks easier than the soundwave to clean up.. do you think it's possible to get soundwave and the chair separate?
yperihitikos
27
Ahem. Let me take a deep breath and say WHAAAAAAAAAAT? The model, the pose, the textures. It's perfect for porting to other games! How did you open the xxx archives?
yperihitikos
27
I don't fancy myself a master of ripping, so I'm going to ask a few questions.
1) Is the model perfectly fixed? If yes then how?
2) How did you put the textures on the model?
3) Where did you get that pose?
Regardless, I think you should release them and make a mod.
blaar
143
1. Relatively fixed I would say. But certainly not ready for paper yet. A lot of cleaning to be done with loads of intersecting faces.
2. When ripping with 3D ripper all the textures was saved as DDS. I open the model and look for the reference number then open the DDS file with the same number and save it as JPG or TGA.
I do not apply the texture in 3DMax when importing the 3DR file. I export the file as 3DS preserving the texture co ordinates and then import into Meta. Then I work it from there and export again as 3DS and import it into Sketchup.
Speaking of 3D Max. I have demo / trial version on a separate PC. So each time it expires, re-store my PC and re-install Max again. Real shlep but that is just about the only thing I do with Max is import 3DR.
3. I posed the model in Sketchup by selecting the arms then rotating them. It looks good now but when you open it up in Sketchup it is messy.
I do not plan to make a mod. Don't even know how to make ragdolls / poses / bones etc etc. lol.
nav
175
Blaar there's a free version of 3dmax..I think I have it's .exe file if you want but I've never used it I think its autodesk 123.Good luck!Their are double faces and such I can get them down to really simple stuff but they won't look too good.. at least I think so.
yperihitikos
27
So far I haven't found any proper textures on my folders. I go to great lengths to ensure that the models I rip are as perfectly fixed as possible. I'll keep posting more models whenever I can. You could take them, put textures on them and upload the skp. How about it?
Porting stuff from other games to the gamebryo engine is easy. You import your model and it's textures to blender, you copy the skeleton from an ingame model and export. I've rigged things for fallout in the past, but I have no idea what to do about the textures. I don't even know how to assign pre-existing UV maps and textures and assign them to the mesh. Here's a tutorial about rigging.
http://www.thenexusforums.com/index.php?/topic/164585-tutorialriggingskinning-and-dismembermentvats/
When I solve this, I'll port Darksiders stuff to fallout.
hellbringer17
42
have you found any news on the textures? these models are all great, but kinda useless without them.......unless someone knows a wayto make textures from scratch?
yperihitikos
27
