Goose #2
Tom,
Your motor car has inspired me to get to work on resurrecting Goose #2
This is a project I started fifteen to twenty years to make a gift for my Dad. I wanted to make a goose for him. I started work from a postcard and some photos of goose #2, as I couldn't find scale drawings.
For the auto body I got a kit for a Buggatti limo, made by Italiari. I had to cut down the hood, make a new radiator, and do a lot of kitbashing to the body, but I was happy with everything but an annoying splice line where the back wheel hole was filled in. Then I got a book on the geese, which showed that the original had that same splice line in almost exactly the same place. The book also had a scale drawing, and overall I had less than 6 inches of error.
I used two NWSL magic carpets to power the unit, built a brass frame cow catcher, and snow plow. I was on a roll, and then my Dad called me and told me he had torn up his outdoor RR and was building inside for his #1 gauge tinplate collection. the Patrly finished goose went into a box for many long years, but it is out now!
Studying the drive I found that one of the gears was damaged on one of the NWSL magic carpet drives. I cut up that drive, and removed the motor ( which went in to my Ho RR's #1 ). I was going to get another magic carpet drive, but was concerned that a current model might not run well with a 18 year old unit. at micromasrk you can get miniature chain and sprokets, the prototuype goose had the first axle powered fron the driveshaft through the differential, and powered the second axle off of the first via a chain drive, so that is what I'm going to do on this one.
I have unhooked the wire leads to the wheels in anticipating using battery power, and will be hauling the whole thing to the RC hobby shop soon to study RC possibilities.
unfortunately I only lettered one side, I have the dry transfers to do the other side, but some times they don't work well when they get old (just like me). If I can't match the dry transfers the whole shebang will get repainted from RGS to State line RR.
what fun!
