F131
F131
i may just shortcut mine if i cant get it right, and i agree about the instructions. that alot more than ive seen for anything else, the halo papercraft i had was pretty much unfold with pepakura designer and put the puzzle together. i think its awesome that you took the time to help guide people that want to build your models, says alot about your dedication to the art. every piece has been easy to understand with just a few seconds of studying, and the detail is amazing. i just want to say thanks to anthony344 for trying to help me out, and to sjsquirrel for the amazing kit.
I don't know if you finished this part yet, but I found that curving the paper with a small screwdriver 1st before gluing made assembling this much easier. Also, when gluing the two wing halves, I made sure the glue softened the paper enough to squish (not too hard) the halves together for a tighter fit.
You will want to make sure there is a bend/angle to the lower wing so the top
and bottom engines don't touch. Good luck.
