scratch building the McKinnon`s garage
kennyrach
Hi all today I started to scratch built a model call McKinnon`s garage was built by Laurie Green .Here at MODEL RAILROADING with LAURIE it a will build model and work with many era .here what I did so far it will be full frame and board by board
Bill Nelson
Good work.
Good work, it is good to see someone doing the board by board thing. it takes time, but nothing produces a more impressive model, please continue to show your progress. thanks for sharing.
when I do the board by board thing, I like to work on a homasote board. I place my plans on the board, and then cover them up with wax paper, and then tack the plans and the wax paper down with thumbtacks.
That way if a stud is being pesky, I can use thumbtacks to keep it in place till the glue sets. I documented that method in my Crooked Creek engine house build, buried in my Logging in Eastern TN on the DG CC & W RR over in the logging mining and industrial section. That buil4 is a relatively recent one, so it will be toward the end of the 40 something page thread.
Bill Nelson
Bill Nelson
Very neatly done; especially at the angled top joints where the stud comes up against the top piece on the gable. It is not easy to get one of those that neat, much less all of them.
are you going to stain or paint them?
good job
Bill Nelson
kennyrach
good job
Bill Nelson
HI and thank i will be oil staining then with air brush.Also did u see my post on stoneycreek WILLS Saddlery & Leather Goods
Bill Nelson
Oil stains do a great job, but I'm too sloppy with glue to get good results unless I pre stain the wood. I have enough trouble cutting enough of the wood to size on my little table saw, in resent years I have got lazy, built up the frame walls, and then spray paint them lightly to get the color I want. Not as pure as pre staining, but much faster, and I get ok results.
Bill Nelson
kennyrach
Bill Nelson
Thank i use light gray sealer primer first then the stain and once dry i use aol/ink wash
kennyrach
OK all here where i am at got the sheeting on and now need to light paint it
Bill Nelson
that looks really good, It has been 35 years since I have done individual wood shingles on a framed up roof, what fun,
great results.
for photography, try getting a couple white , and a couple black sheets of foam core, then you can block out distracting backgrounds and show off your excellent workmanship better.
Once again, thank you for sharing. This stuff is so much fun lets hope we can get more folks to try it.
Bill Nelson
kennyrach
great results.
Bill Nelson
Thank i hear i try the white board and take other pic
