Closet Astronaut
Well I thought I would get started on Scott's 1/4 Merc capsule but got side tracked putting together the materials. I was so impressed with Surfdukes Apollo SM,& CM, I thought this would be the crown on top of Greelt's 1/48 Sat V. The detail in his designs warrant only the best, even though he hasn't finished.
So, for all you 1/48 Greelt fans I've embarked on the rebuild of the service and command mod. making it as realistic as possible. I found some mirror paper and different types of metalic paper and started on the CM.
You can't print on mirror paper, so after some trial and experimentation I figured out what to do, here are some of the results. :idea:
