Aliens Cheyenne Dropship
The ship is done but here comes the extras, and each structure is a model upon itself. The base for the antennae array should be done twice for the two options, but I am going to do only one option for now, maybe the other one will come later, like next year 2011.
First I will start with the easy part, the storage sheds/boxes. The ends are laminate and the one with the relief design was cut and laminated to show depth. There is an open panel which is cut out and hydraulics made from tooth pick segments and strip of paper is inserted inside of the opening. For the lift device segment. The sliding rails are cut into the base and laminated. The sliding base is made, and trimmed out with hydraulics are scratched built and placed inside.
Looking at the landing base, it also has the added possibility of being used as a landing pad for the Warhammer Thunderhawk and other Imperial acft. The buildings and accessories can also be used in the Warhammer universe.
