Sd.Kfz. 9 Famo (Angraf 5/2005)
Status
snake7
continue from previous post
the mechanism is movable
i did a quick animation to show you how it works
snake7
i assembled steering shaft... and i am sorry, but i must return to bad things
gluing place for the supporting bar, that connects shaft with rear wall, is high for about 5 mm. i painted it, but eventually it will be hidden under cover.
the joint between steering shaft and steering mechanism at the bottom is wrong - missed 5 mm of sleeve that connects them together. you can see that i added the missing part to compensate the gap
and the cream of the pie - there must be a disk at the bottom of the shaft, but apart from the case that there is a difficulty to insert the disk into place, there is no room for it at all. so i was forced to get reed of that part. at the end, i must be thankful that i manged to join the shaft at all
the wheel itself will be glued later. the reason - it can obstruct the assembling of other parts, for now
also i glued the the engine cover, but only at front. rear part will be glued later, when i'll attach additional part to the rear wall
bugs:
explained earlier
snake7
Hello modelists
today i assembeled dashboard
at general there were no porblems, but i was in need to cut a little at the bottom of the panel, because the shaft got in the way
also i did imitation of a glass covers on the clocks and put some levers
bugs:
none
snake7
thanks consistseeker
when i prepared next parts for the assembling it turned out that a lot of parts are missing:
72b -the inner side of of driver compartment sidewall (a big one)
82b - the bottom side of middle mudguard (also a big one)
74k, 74l, 74m - those are parts of big hatch from rear (on second picture)
a minute of silence...
got myself together and continued the project
eventually, no matter how i tried, the color of the printed part, of the side of driver compartment, didn't match (part 72b that missing)
so i found the spare color at the end of the journal and made the parts from it
also i assembled the floor
as i wrote, parts 74k, 74m, 74l are missing too
as usual, i cut those from spare color
i am starting to get used to it and its no god :)
when i tried to insert front floor to its place, the fuel tank got in the way, so for future assembling - glue it after you put the floor in the place
snake7
hellofriends
i did another push and assembled front floor with all the levers and pedals
all of those are connected to proper places, as you can see on the pictures
left pedal connected to gear coupling
middle pedal connected to air pressure cylinder that responsible for the brakes
right pedal connected to engine throttle (doesn't seen on pictures)
left lever responsible for activating tow drum and connected to the end of transmission box
middle lever, handbrake, connected to two stoppers on shaft drums
left gear lever connected right to the gear box
also i assembled rear compartment walls
the story about missing parts still doesn't end: middle part of front wall is missing. X strips on the both walls are missing too
bugs:
part 75b - missing. made from spare color
part 75g - missing. made from spare color
part79j - not right, cannot be glued to place, no space for it. disposed
mysteroid
Thanks for the continuing inspirational work Igor! :thumb:
I've been in a building slump for the last month or so. Good to "build" vicariously through your marvelous build!
Steve
snake7
thanks Steve :)
continued with driver and soldiers compartment
put seats in place.
they can be raised
shotgun219
WOW! I had heard that this model was impossible, but yors looks great! :thumb:Right now I think I'll stick with 1/72, though:mrgreen::mrgreen:
snake7
thanks shotgun219
i didn't quite understand your question, but if you mean how it was assembled so that the weels are moving - it is the design of a model. you can search on previous pages where i build front suspission and look there about how did i managed to make it movable
om the temporary, if you ask how i did a picture with the wheels pivot, its a simple GIF file, that i did from a few shots with wheels in different positions
snake7
a little update
assembled and glued in place a couple of boxes, first aid kit and few other things
bugs:
detail 81a - one side of a box is white, but still seen from the side and doesnt covered complitly by the seat, need to be painted
snake7
Hello
some progress with the cabin
middle mudguards didn't fit well, so i was in need to cut and adjust it properly
also they weren't in line with front mudguards, but i fitted the step between them somehow
sidewalls also got a problem. the pockets of left/right signals (red ones) were interfering with boxes inside the cabin. cut and adjust, cut and adjust..
eventually i assembled the cabin somehow, but i don't like the result.
from other side, there's no other way, only if i will break half of a model to fit it properly
i must confess - i lost all the pleasure of building this model
now i only want to finish it
RealHawkman
Great work
Hi, i'm new at this forum and I'm amazed about the high skill people like u have. Continue with ur great work, i'm very impatient 2 c ur model finished.
Regards.
snake7
Hello guys!
thank RealHawkman
after a wonderful vacation
i am back to my sorrow project..
i made some instruments and placed them in the cabin
as usual, a lot of parts were missing, especially all the fastening belts
bugs:
missing parts 111a, 111k, 111j, 111g, 111h, 111i, 111l, 111m, 112j, 113d, 113c, 113e
did all of them by myself from spare color
gregh
Fantastic build!!!! you have shown all of us your great attention to details and your modeling skills. :goldcup:
snake7
thanks Gregh!
I've assembled 7 Mausers, but the wire, for the big handle they must be attached to, has been ended, so for now i am switching to front glass
bus: none
snake7
that is a fantastic model. The skill and detail are astounding.
thanks!
I've assembled front windshield.
The design of it was unbuildable, but i managed somehow to bring it to proper look
Also i attached some handles and the steering wheel
Mousers will be placed at the end, when i will fill completed model with al kind of "garbage" :D
bugs:
windshield is one huge bug :)
Status
