Bill Nelson
progress
I came up with a relatively easy way to raise the track up above 6 feet to allow me to walk under int in order to enter or leave the railroad room.
I had originally planned on making the benchwork over the storage cabinet a neatly built box, with a recess in the bottom that would fit tightly on the steel storage cabinet I got lazy and used gorilla glue to secure 2x4s to the top of the cabinet. if this construction ever has to come off too bad, cause the benchwork and the cabinet are unlikely to survive the forces needed to separate them.
I'm going to add some more risers on the front of the cabinet area to better support the plywood sub road bed, but I'm waiting to do that, as I think I can make a little piece of dramatic scenery there, probably involving two bridges and three or four waterfalls, so I want to do some careful thinking before I put the risers in so they won't be in the way, and so that some extra bracing can be added, as cutting that plywood anywhere will reduce the strength considerably. I may end up leaving the plywood in place. and casting and carving a masonry bridge to fit around it, like I did down in Montgomery Furnace.
My original plan was to have this top shelf plain sterile staging, but I'm thinking now that some rudimentary scenery might be in order. Including an iron mine, and a logging camp . If I could do that and have two passing sidings, and a short siding , just long enough to park a goose on, then that; along with what is available down in Ridgemont/Statline and the Georgia staging would allow me to have two iron ore trains, two log trains, two passenger trains, two freight trains, and two geese ready to go just about any time.
Bill Nelson
Bill Nelson
