Logon's run pistol
movieman
90
9
I have just uploaded a 1:1 scale papercraft logans' run pistol which you can download once it has been cleared. I have pictures, but due to this forum restrictions of 15 posts before you are able to add links to the pictures you will all have to wait, but the model is well worth looking at, I will also upload some other models I have done including a classic cylon rifle, logan's run tracker and a model of the classic spaceship from the 80's series Blakes 7.... the liberator.
all the best steve
movieman
90
9
Logan's run Follower
I have now just added to the download section, the follower device used by the sandmen to track runners, this will only be available once it has been cleared.
Steve
Elliott
645
Approved. :thumb:
You may want to consider making these available in PDF format as well. Your models will be available to a wider audience as many people don't, or can't, keep up with the latest PDO viewer release. :)
movieman
90
9
Sandman SD gun
Here is a picture of a completed sandman SD gun that I did last year.
vulcan8630
122
5
18
They call it..."The Rock".......
Hey, this looks good....Interesting, I was dabbling in design and this was my next project...I noticed some paper modelers use wood putty, spackling, or "super glue" to laminate, stiffen and smoothen their paper models did you use any of these techniques on your model?
movieman
90
9
No I use fibreglass resin or I mix up some fibreglass mud (FM) whist is a 50/50 mix of fibreglass resin and car body filler, think it is called bondo in the USA... and P38 over in the UK, you simple brush it on and it set smooth, any floors can be sanded out..... proves to be very strong finish, though with big items and armour I back that with fibreglass tissue, which is easier to use and you get a smoother finish than the heavy duty fibreglass strands, 2 layers of tissue is stronger that vaccum form plastic and about the same weight.
steve
movieman
90
9
I have uploaded a re-model of the logan's run sandman's deep sleep gun in to the download section, once approved you can download it.
