Star Trek Overhauls
Paragon
814
48
38
37
Greenville NC, USA
www.freewebs.com
I've got a sister thread running on Papermodelers for this project, but figured I might as well share here as well. I'm currently redesigning some of my favorite Starfleet ships, making them more accurate, easier to build, and giving them better textures.
I've completed two so far, the Steamrunner class and Prometheus class starships. The Steamrunner is mostly an update of the model that was already available on my website, while the Prometheus is an overhauled version of Jay's release, which can be built in multi-vector assault mode.
First things first, the Steamrunner:
With the old version:
All of the classes of starship present at the Battle of Sector 001 in First Contact:
E
ekuth
Sweeeet! Thanks for cross posting, paragon!
Love the Prometheus... Always did want a model of that one. :twisted:
sidewinder81777
Midnight Modeler
Apr 30, 2009
238
27
33
46
Florida, USA
Great, we need a good new orleans class model. the one thats out there looks like it would take too much work to make buildable, and the textures are really blurry
Paragon
814
48
38
37
Greenville NC, USA
www.freewebs.com
Progress on the Durandal! I've decided to give her a standard captain's yacht, the Aeroshuttle, and what's more, I've decided to actually build the damn thing at 1/1900 and make it fit in the berth. The result is a 1.5 cm wonder. I think I might need to be checked out by a psychiatrist.:razz:
E
ekuth
I've ran across this before with lamination. Only real way to solve it is by cutting each layer first before lamination...
Which is almost as much of a pain as cutting it after. :rolleyes:
Elliott
645
While the psychiatrist is checking your brain you might want to have an ophthalmologist check your eyes. :p
That is seriously good work! :thumb:
Would it be easier to do a general cutout through the lamination, stiffen the cutout edges with c/a then do the final work with sanding sticks/jeweler's files?
Paragon
814
48
38
37
Greenville NC, USA
www.freewebs.com
A jeweler's file! Brilliant! Where can I get one of those?
Paragon
814
48
38
37
Greenville NC, USA
www.freewebs.com
She's done, finally.
A bit of info about these images:
The first few demonstrate the mechanism in for the sliding nacelles. the "trucks" have to be able to rotate freely inside the nacelles so they can turn with the curve of the track. The nacelle is built in two halves, and then assembled around the mechanism.
The ship herself:
And some details. I'll explain them tomorrow:
Paragon
814
48
38
37
Greenville NC, USA
www.freewebs.com
Alright, some info on those details.
First up, the forward "trench" houses the secondary deflector, two torpedo launchers, and a forward targeting sensor. On the sides of the saucer are the additional targeting sensors behind the RCS thrusters. You can tell they were inspired by the Defiant.
The side of the saucer shows the detail, meant to sort of merge aspects of the ships designed for Voyager (Voyager, Prometheus, Equinox) and First Contact (Sovereign, Steamrunner, Akira). Small pairs of escape pods, the forward dorsal phaser array, and some inset windows. You can also see what resembles a 23rd century phaser bank. This design was revived by starfleet engineers to allow installation of pulse phasers not limited to forward-firing positions (like the Defiant):
Two more pulse phaser banks can be seen on the front of the saucer. There are no rear firing pulse phaser banks, they are primarily an offensive weapon on Durandal. Two more torpedo tubes can be seen, the housing located just forward of the deflector and captain's yacht:
The captain's yacht, standard Aeroshuttle design. The main deflector is also visible:
The warp core and ventral impulse engines:
Aft ventral torpedo tubes. The housing is of the same design as the forward ventral structure:
The warp nacelle junctions include phaser arrays:
Durandal's nacelles are heavily armored, to increase the chances of maintaining warp capability in battle. When retracted, most of the vital areas of the nacelles are covered by thick armor on the secondary hull, save these three small warp field grills.
With nacelles retracted, Durandal's shields shrink to fit the smaller shape, allowing a 26% increase in shield strength. The nacelles also help provide additional power to vital systems when retracted. Plasma vents are visible along the spine of the ship. Below them are the aft dorsal torpedo launchers, above them the secondary shuttlebay.
