Uhu02 "Discovery" Model
J
jagolden
I'm considering many different ideas for the spine support.
My concern with a wood dowel is that it will bend (warp, sag) over time - even oak.
PVC pipe and acrylic rod will have sag.
Maybe thin-wall brass or copper tubing filled with expanding foam?
I do have a 1/12 Gemini capsule w/ docking target hanging by a single line over my desk in the basement (location: New England, US).
I used a wood dowel down the center of that. I does not seem to have sagged over the last 4 years, but with the disparity of shapes, it would not be too noticeable unless severe. The length is just over 36".
With the Discovery, and the repetitious shapes, I think any sag would be much more noticeable.
Thoughts anyone?
NYC Irish
172
Cork Ireland
Im thinking that a 3 point system to hang the model might be the best option...Start, middle and end point...leaving the middle adjustable for any sag that may develop?
John John
J
jagolden
John John
JohnJohn,
That's probably going to be the best way to handle it.
I like the 1 point hanging system because it gently spins easily. But sure could still make that happen with a 3-point system.
I do have to say that on the Gemini, the wood dowel has only about .25" thick and it has held up. you can see a little point sticking out the end on the Target in the photo.
NYC Irish
172
Cork Ireland
Sorry for the double post..there seems to be 2 identical threads but...
Thanks for the heads up on 13X gents
Bit of note here...I went to local Hardware store this morning and brought along a sample of page two, to use the members as guides for suitable Diameter Dowel, Got one that I was happy with as you see in Picture 1 but when I attempted to wrap it with the main spine members I got a significant gap as seen in Picture B.
Both pages were printed with same scaling sizes and I have cut as much of the black line off the spine member...any hints or tips?
Thanks in advance
Mousemuffins1
129
well, there's a couple of ways you could deal with this.
1: cut the holes in the hexagonal widgets a bit smaller(just inside the black line), which is probably what I'll do.
2: cut thin strip from a second printing of page one to fill the gap. (I may do this as well).
As said above, I'm going with 8mm dowel.
Gixergs
1,438
1,493
143
Hi, I see on Uhu's site something about Gen11 but I can't get the page to translate very well, would I be right in thinking that he is working on Chitty Chitty Bang Bang?
12,338
BUMPED for priority reasons - do not bump in old threads
