VF-1 Valkyrie
Getter1
583
Spokane, WA
Wow, that picture almost gave me Déja vu Getter.
I did a very similar injury to the very same finger, same hand, same side of the finger. Pretty similar bloody mess too haha..
I fractured my finger in a couple of places at the same time too though, so it's been a bit crooked ever since. Don't worry about the range of motion, that will return in time. Keep up the physio though! can't stress that enough!
Hey TF,
It was broken to :p Middle and index tip and the joint behind the middle tip :( It's a bit crooked to :p
G1
57townsman
168
Cypress, CA
WOW! That was a nasty bite you got there. Glad to see its healed up and you're able to start building again :thumb:
Keep up them exercises.
SteveK
ltla9000311
174
Fresno, California
Build pics
Okay guys, I got the go ahead from Getter1 to post these pics in the thread. This is a work in progress of the VF-1A from DYRL. Getter was more than generous in sending me this one for a beta build of sorts. While I did stall on it the building shall resume shortly! This will have the Strike pack with the cannon on the right side when done.
Janx
132
Weird not getting auto updates on this thread, didn't realise so many replies had come winging in.
If any one can get me screen caps of the launch arm I'll give it a go and try to get one sorted for this project.
Getter1
583
Spokane, WA
Alrighty, the Striker Cannon has been built and installed on the test Battroid.
G1
Getter1
583
Spokane, WA
Battroid shots.
G1
Janx
132
I have two working hands and yet... practice practice practice...
I'll dig out my DYRL vid today see if I can find the launch arm shots.
ltla9000311
174
Fresno, California
Hey janx, I have the DYRL movie book that has the screen caps and 2 line drawings of that arm. The screen capture shots are too dark to be usable, but the line drawings might help. The only problem is I don't have a flatbed scanner!:curse: I think 57townsman has the same book AND a scanner. I sent him a PM about this same that same thing a few days ago, maybe a little peer pressure might help?:twisted:
57townsman-I hope I didn't overstep my bounds here. Just rying to give Janx a little more info for the arm. He would design it WAY better than I ever could.
ltla9000311
174
Fresno, California
Janx, I had a thought here, I took pics of the two line drawings from my book. While not as good as a scan maybe they can help with the overall shape and placement of parts? As far as color goes, I can pull my movie out and look plus take a look in the bookwith a bright light.:eek:ops: I wish I could be of more help here.
Getter1
583
Spokane, WA
I whipped up a GU-11 Gunpod in the closed position last night to mount on the Fighter model. I printed out the un-textured version for the test unit. fits and looks good, however the stand for a gear up model will have to be notched to accomidate the Gunpod.
G1
ltla9000311
174
Fresno, California
Getter, how do you roll those tubes so well? What weight paper are you using for that? :confused: I have 65lb cardstock I used on my model, but I just can't seem to get the rolling quite right. What I'm saying in a backwards way is, you kick A** when it comes to building!:thumb:
Getter1
583
Spokane, WA
All in 65lbs. stock here to.
Start rolling your tube parts over a dowel larger than tyhe diameter of the tube. Re-roll on a smaller tube and progress down to smaller than the part diameter. Apply glue to the tab and lighty set it. when it begins to grab and is alligned properly press lighty tight with needle nose pliers. For tubes too small for that have your final tube inside and press on the dowel to firm up the seam.
Oh do you have details on weapon mounts in that book of yours ;) I need what I can get on the wing mounted weapons hardpoints if you got em.
G1
