A lot depends on the conditions in your layout room. My layout is in an unheated/uncooled room in the basement. The walls are well-insulated and it's usually "comfortable" in the room, although a long spell of cold weather can make it a little chillier than I like. There's a suspended ceiling in place, and the floor is unpainted concrete. There
is a dehumidifier running, elsewhere in the basement, during the summer.
I soldered
all of my rail joints together, then cut gaps where I needed to be able to isolate track sections. Not counting sidings and passing tracks, there is about 145' of mainline track in service, with another 45' seldom used (it currently dead-ends in the middle of nowhere). Another 65' of track is needed to complete that track to the northern terminus of the line. While there
is a bus wire for the fascia-mounted throttle jacks, the power is connected to the track only at the power pack. I've had no problems with expansion or contraction of either the rails or the unpainted wood used to construct the layout, and no problem with current drop-off as the trains travel away from the power source, which is DC. Other than an occasional dusting and vacuuming (well, once in 15 years for the latter
:-D), not much in the way of maintenance, either. I don't clean track, ever, unless I've been working on scenery in a particular area.
Wayne
