So....the general consensus is that the greater the load, the more efficient the locomotive..?? That doesn't make sense, as any system's efficency degrades with greater demands made of it....
(I'm playing the devil's advocate here....). :twisted:
sign1sign1sign1That's SICK!!!! sign1sign1 i never thought of it that way
It's a curve on a grade... The trick (Enginneer's job) to make sure the "efficiency" doesn't go below a certain percentage, that is to say that the locomotive should run smoothly, and at a near constant speed, no matter how many fulls or empties are behind her.
Therefore, it could be said that it doesnt matter what the locomotive is pulling, over the same 5 miles of track, at the same time of day, at the same temperature and humidity (Temp & humidity effect air intake and cooling) the locomotive should use the exact same amount of fuel on avreage
That's where they get us with car mileage MPG.... it's NEVER right.. it's NEVER the same.. and it is so deceiving....
A 35 MPG car should get 35 MPG, but that's an average of hundreds of miles of driving in a controlled situation.. For instance Highway and city... As soon as you "mix" the 2 - the mileage will go down just a mile or 2
City driving will always depend on how many stops you make, how long you stop with the engine running and how many times you stop and restart the engine.
So... To transfer this to the locomotive, this was probably done in a testing atmosphere - over 4 or 5 - maybe even 10 tanks full of fuel.. and they got 20 or 30 "Ton/MPG" readings... When they averaged them together.. they were probably around 410 tons/MPG
But the BEST run was 420.. That's the bragging rights!! In order for them to state it anywhere - they Must have the documentation readily available for any potential questions as to the authenticity... The Consumer Protection Agency and the Free Trade Act say so!!
