Klingon Cruiser Bloodwing - 1/1700 scale
Status
D-WHALE
Utopia Planitia Engineer
and here without the cubes:
D-WHALE
and with the Armada:mrgreen: (all models in the same scale (that a problem with the BoP:cry:))
shiftdel
Pericles inspired me this model to also build! it is also in 1/1700, but more brightly! some parts I corrected, so that they are to be built better and more easily! the nacelles wasn´t correct!!! but it is a cool model:thumb: I want more of this stuff from you, shiftel:twisted:
here are pics with scale cubes (the smallest part is approx 1 cm "big"):
What's wrong with the nacelles?
BTW, nice fleet, and killer base that one under Bloddwing!!
D-WHALE
I will make some screenshots for you:cool:
here is another pic of the fleet!
Chekov: "Captain, Captain! Is that our new screensaver?"sign1
D-WHALE
thank you guys!
@Periclés
thx for the inspiration:thumb:
@shiftel
here are the pics! first the screenshots of the original parts with the errors!
(to the last pics: you can see, that the nacelle grill goes through the main nacelle! but there is a cutting line!)
D-WHALE
and here are the corrected parts!
to the 1st pic: you dont need the inner grill for the build! but then you need the complete outside grill!!!
to the 2nd pic: if you use the complete warp nacelle, you must cut out a part on the grills! but that can you only make in Photoshop!
I hope you understand me! my english is not the best!
best regards
Marko
shiftdel
thank you guys!
@Periclés
@shiftel
Oh, that's error? That was because I did, at first, split the nacelle into 3 parts, but I found that was a pain to align all 3 (those on my prototype aren't), so I created faces conecting both ends, but forget to reallign the sides, that cut line in fact is a fold line, that I forgot to get rid off.
Well pointed, I will correct it on my original model, and before to release the Kleeve, which shares the same nacelle layout. Not sure if I will get back to 3 parts layout, though...
Thanks for pointed it for me :)
D-WHALE
no Problem man! you did a good job!
Btw: you can increase the resolution of the texture files! or can you send me these files?
shiftdel
That is the original resolution of the texture files, they are just 256x256 in size, I can send you the files, hope you can increase the resolution; although I think would be easier to ask the author if he has better resolution textures.
D-WHALE
Okay! i have no problem to change the resolution of the texture files
:cool: at the i make the same with my Nebula-class:mrgreen:
E-Mail: dwhale@gmx.net
thx for that!
BTW: the tip with the errors of the nacelles gaves me Gomidefilho:wave:
Status
