EZ Command question
Southsounder
9
I just bought this to get into DCC since it fit my small budget. My question is I have programed two locos but it won't take anymore, I keep going through the steps but it just not taking them from the #3 button. Any suggestions? thanks
Southsounder
9
Loren, Nice quote, I have taught that myself.....I thought that may be the problem, but all the other loco's I've tried to program are still able to run on #three
Southsounder
9
I am just trying to get my six DCC loco's programed it stopped taking them after 1 and 2, but I still use #3 the run the others on, it just won't let change the ones I have programmed or add any others, I may try to call the help line this week
L
lester perry
have you called Bachmann? what did they tell you? I called them a couple of days ago about a friends Loco that would not respond to any thing I tried. Thier Tech support was worthless. The man told me to program it for #1-9 because Bachmans sytem only went with those numbers. I tried to explain to him that I wasn't useing Bachmanns system and he said that was the problem. after a little more dicussion he said Bachman is new at this DCC stuff and he dosen"t know much about it. this was thier tech support guy! I finnaly figured out that it was a soundtraxx tsunami decoder and fixed it for him.
Les
Nomad
1,570
Elks Plain, Washington
Southsounder, did you get your loco's programed? If not, are you using a programming track with the resistor in line?
If you are, take all other locos off the track and program on the main, or take out the resistor.
When I was using EZ Command, I had one engine that could only be programed on the main.
Loren
Southsounder
9
Thanks Loren I'll try that, I have been out of the State the past week and thanks everybody else for the tips, ss
L
lester perry
I was thinking, maybe if you know someone who has DCC they could program the locos for you then just take them home and run them.
Les
Southsounder
9
Called customer service at Bachman, not very helpful.....called my local hobby shop and I am going to meet with him and try to program that way, and then send Bachman back the defected item....they said that would be 8 weeks at least until they could return it.
L
lester perry
From the replies you have received here this might be an ongoing problem for the EZ command system. If you are going to get a better system later and If your LHS or a friend will program for you it might be a good Idea to just live with it.At least 8 weeks is a long time to be with out your railroad. Just a thought.
Les
steamhead
2,360
Brownsville, TX
South...You might check the B'mann forum. I've read that most "repairs" at B'mann involve changing the defective unit for a new one....I believe most folks were referring to engine problems, but the same might apply to their DCC systems. 8 weeks sounds like a long time for a B'mann product. Check it out...
Southsounder
9
After a couple of beers and stairing at it for a long time I decided to do some different combinations of the instructions and lo and behold, it worked! thanks for all the suggestions over the past couple of weeks...
L
lester perry
Great news but I have a question. do you remember what you did
Les
N
nachoman
a PS here -
How many speed steps does the Bachmann EZ command use?
Kevin
Southsounder
9
The instructions and the second guy I talked with at Bachman (who was very nice and helpful, unlike the first person I spoke with) stated to press the the programing buttons at the same time. What I ended up doing was pressing the "3 button" then the "program" which gets it blinking then the number I wanted the loco to be programmed on. The button blinks faster and then the "program button" again after the loco moves back a forth a little. Done...The "Program button" may be marked with a different name, I am not looking at my system as I type this.....thanks again and good luck with your layouts
