TruckLover
Mack CH613 & 53' Trailer
Hi guys, decided to make a new thread to post the progress of the new shelf layout im building all the way around my room.
Name: Unknown as of now lol
Scale: HO scale
Prototype: BNSF and UP/CNW
Size: 10'x12'x18" with below layout staging yard
Era: Modern
Mainline Run: 44' (double main in some spots)
Minimum Radius: 24"
Turnout Minimum: #4
Maximum Grade: 3% (to staging)
Benchwork: 15" heavy duty shelf brackets mounted with lag bolts into every other stud. 1/4" plywood mounted to brackets with Carriage Bolts for layout base with 2" Pink foam glued to base.
Height: 50"
Roadbed: WS Foam
Track: Atlas Code 83
Scenery: Plaster
Control: Digitrax Super Chief Command Control
Scale: HO scale
Era: Modern
Minimum Radius: 24"
Turnout Minimum: #4
Height: 50"
Roadbed: WS Foam
Scenery: Plaster
