TruckLover
Mack CH613 & 53' Trailer
Hi everyone,
Im finally going to get a chance to ACTUALLY run trains fot the first time Can you believe it? Ive been in HO and N scale for about 2 years now and I havent ever had power in my tracks before :cry: ops:
Well things are going to change. I was permitted to build a 15" shelf layout around the walls in my room. Im going to use the Walthers Cornerstone Backround Buildings and a couple smaller Walthers buildings. This layout will go ALL the way around the room complete with a "lift out" bridge that crosses the walkway into my room as well as a under table stageing yard. Layout will be 48" tall around the room and im going to use 15" heavy duty shelf brackets and 1/2" ply for the benchwork.
But I also need to get my first DCC system too. I want a GOOD one and im not concerned about how much it is. Im looking at it as an investment and it will be something i will be able to use on many layouts to come. So I want it to be a mid-to-high end system. I havent the slightest knowledge about DCC so im really looking to you guys for some help and direction on makeing the right choice here
Im looking to run a few trains, maybe 3-4 but on my furture layouts i want to be able to run more then that so I need one that can handle more then what I will be using it for right now. I also need to get decoders for my engines.
Any suggestions and direction on a Mid-to-High end DCC System and some decoders would really help me out.
Thanks in advace guys
