O to On30 Diesel Conversion?
riverotter
Midwest Alliance Rail Sys
I'm building a switching layout as my first foray into On30 and due to space limitations, I'd like to use a small diesel switch engine (e.g., an SW-1) instead of a steam loco (I know it's probably not prototypical). How hard would it be to convert, say, an Atlas O 2-rail DC switcher to On30, and what work would that involve?
Triplex
On30 runs on HO track, so an HO mechanism would be a better starting point. Plus O scale body components.
Squidbait
Recovering ALCO-holic
Yep, just pick an HO mechanism that works for you, and build a superstructure in O scale. That could mean building something from the frame up, or just cutting the roof off the cab and raising it to fit an O scale person.
Or you could get one of these.
riverotter
How about something like this as a starting point?
It's an Atlas O.
Is there any chance I could just push the wheels closer together (to HO gauge)?
Thanks for your feedback!
riverotter
That sounds like a good idea. I'm using Peco code 100 On30 track (with wider tie spacing than HO track), so wheel flanges should be no issue. Maybe I could take an HO SW-1 mechanism (for example) and find an O scale shell that would fit?
Squidbait
No. Not without major reconstruction.
If you want that style, you could raise the roof on a Bachmann Plymouth switcher:
Model Power makes an MDT that is actually too big for HO, it might be close, or less work to convert:
riverotter
Do you mean literally take an HO scale switcher and just build up the cab? That would certainly be about the quickest conversion!
riverotter
Cool! I'll get busy looking for one of these!
riverotter
Actually, I just bought an HO MDT and one of the cab conversion kits from Boulder Valley Models. Of all the excellent suggestions, I thought this was the best way for me to go (given my modeling skill level - if you could call it that!).
P.S. I put one of my HO SW-1s on the On30 track with an On30 boxcar and what do you know -- the couplers heights matched up perfectly!
sumpter250
multiscale modelbuilder
Until I had a chance to look at scale drawings of thirty inch gauge rolling stock, I thought it was just a coincidence that the coupler height was the same for HO, and On30.
I have made the commitment to set the couplers at the same height as 3' gauge. (my brakeman has a back problem :mrgreen: :mrgreen: :mrgreen:)
Pete
HarryHotspur
Mechanically and electrically that will work fine. The problem is the shell will probably look grossly over sized. The reason is that narrow gauge locos were usually built smaller in almost all regards (HxWxL) than their standard gauge counterparts.
I don't know if the SW-1 was ever build for narrow gauge, but if so you might be able to find the prototype dimensions on line and compare them with O scale shell. Of course, if there was no prototype, you can freelance whatever you like - actually, you can do that regardless if it suits you.
A lot of modelers say S scale standard gauge shells are about the right size for ON30 steam locos, so you might want to consider this approach. My personal rule of thumb is that "If it looks OK to me, I gonna do it." Good luck. :thumb:
Triplex
There were no narrow gauge SW1s. That does remind me, though: EMD Export Page A 6-axle SW1200 to spread the load. I believe this is metre gauge.
Locos of North American standard gauge dimensions have been built or converted for 3' and metre gauge, but they'll be a bit big for smaller gauges.
Squidbait
...or your link didn't work, I tried it both places and it came up with a blank page !! :mrgreen:
It was working. Apparently Bachmann is re-tooling their website or something, because their product search is "temporarily unavailable".
EMD exported SD45's to Brazil for a meter gauge iron ore railroad. To get around the weight on the rail issue, they used D trucks like the ones used on the UP Centennials making the engine a DD45M. I've seen HO SD9 chassis used under EMD G12's for a cheap and reliable way to power narrow gauge diesels.
Greg
C
Catt
Some food for thought or a picture is worth a thousand calories :mrgreen:
Couple lousy pics of one of my 0n30 critters :D
What it is/was.
Loco is based on the KATO HO scale NW2(Athearn SW-7 bluebox loco would work too).The walkway and steps are scratchbuilt,while the cab is a modified Bachmann 0n30 steamer cab.
The single exhaust stack is a cut down drinking straw.I made cab doors .but I just can't seem to talk myself into installing them.Future plans call for a rear headlight and working ditchlights on both ends (this part of the Grande Valley Railway is a modern day narrowgauge railroad)
