XTrkCad download has moved
stump7
alexander
just wondering, about Peco SETTRACK (note, settrack, not streamline) curved turnouts, they are not listed
does anyone know there specs so i can add them myself?
thanks
Alexander - I have them - email me direct, and let me know which ones you want
chacmool at lineone dot net
Shortliner(Jack)away up here in the Highlands
Help CAN'T INSTALL xtRKcAD On Windows XP Pro
Hello, I have gone to Yahoo, and downloaded the newest file no less that 5 times, and when I try to install it, I get an error message, and it will not install. I also checked to make sure I downloaded the correct one for Windows, still won't install, any help would be appreciated. Thank's Again, Duane sign1
Planeshavings - send me an email chacmool at lineone dot net and I'll send it to you - it will be a clean .exe file. do you want v3.2314 or v4?
Shortliner(Jack) away up here in the Highlands
Maineiac
New Model Railroader
Dansco said:
Update! I Downloaded and installed from http://www.xtrkcad.org
New build does not require registration code.
Also, linux version works fine on suse 10.1
Thanks
Thanks for the update. I've tested the new build, and it works great in Windows Vista, if you're fortunate enough to be using that.
ozzy
well i down loaded it 2 times, says it is down loaded. but when i click to open it it just tries to download it again.
Rob24
Thanks Ron! :thumb:
EDIT: I have no idea what I am doing wrong. First it said it would take over an hour to DL. Some how that failed. No I am getting an Error saying it don't excist.....
I get the icon on my desktop, but it wont open.......
I turned off my Pop up blocker... Lowered my security settings.... ETC.. I'm lost for ideas.
Another EDIT: I give up. I have tried everything I can think of.
Kevinkrey
I have never used this program, but I just downloaded it and its pretty fun, Ill definately play around with it.​
RonP
Member of the WMRC
You on windows ? xp or vista
Thanks Ron! :thumb:
  • xtrkcad.zip
Rob24
Ron thanks for your support. But it still does not work for me.
Everything downloads, it says download complete, then I click on the icon it trys to download again. Once it says download complete all the icons on my desk top blink..... then it's back to square one. :confused:
