doctorwayne
The catalogue shows both the blind drivers and the flanged drivers as being the same diameter (not that that necessarily means much) - perhaps the bearing seats in the frame are deeper where the blind drivers are installed. If this is so, new drivers won't be any better for touching the rails. Check your loco's frame before you order new drivers - you could use brass shimstock, in the appropriate thickness, to fix this problem, although the exact method would depend on the bearing style.
Wayne
Wayne
