Riverside packing house … kind of …
cnw1961
846
Germany
Oh man, I wanted to build the National Orange Company packing house in Riverside http://scph002.home.netcom.com/riverside_national1.jpg but somehow I got it wrong :eek:ops: and ended up building this http://scph002.home.netcom.com/riverside_national2.jpg :mrgreen:.
Seriously, I planned to build the front half of this really interesting and good looking structure, but then I thought that the backside would fit better on to my layout. The rear is not as beautiful as the front, but somehow I like it too. With the help of the scale drawings from the "Built in America" site, I could easily do HO scale drawings to build it perfectly to scale. The length of the HO model is 2 ft. I only made one major change to the structure as I mirrored it, because it will look better on my layout.
BTW, Russ, thank you for the tip on the citrus modeling group a few days ago :wave:.
I started by building the structure using .080" cardboard.
Then I started the tedious job of cutting nearly 300 little boards and gluing them to the walls.
287 (or 279??:mrgreen:) boards and several hours later, it looks like that. Now I have to decide on the roofing material I want to use. They changed it several times on the prototype during the long years this structure existed, so I have the choice.
bigsteel
Call me Mr.Tinkertrain
Dec 12, 2006
1,319
Cincinnati,Ohio
thats on great looking structure there kurt! those boards may have taken long but they were worth it :thumb:,they look so much better than scribed boards.ow do you plan to weather this structure?--josh
steamhead
2,360
Brownsville, TX
WoW..!!! 287 pieces cut..?? Did you cut them from sheet stock, or was the cutting to length only..?? However you did it, it sure looks amazing..!! :eek:
What kind of cardboard did you use to "frame" it up..?? Also, what material are the boards made of..??
Look forward to seeing the finished product..!! :thumb:
cnw1961
846
Germany
Kevin, Richard, Steve, Gus, thank you for your kind words :wave:.
Gus, I had a 40" x 4" x .040" sheet of basswood that I cut into 12" x .120" strips. Then I cut the strips into pieces of 3". Must have been nearly 300 pieces.
As I learned a few days ago, the type of cardboard I used is called chipboard in the US. The "bushes" are Silflor prairie grass tufts sold by Scenic Express.
doctorwayne
3,516
Canada, eh?
Looks great, Kurt, and a nice addition to your layout. I'm looking forward to seeing the finished job. I also like the look of the tracks in those last two pictures.
Wayne
w8jy
137
Au Gres, Michigan
I think it is a plot to give the rest of us an inferiority complex! That is truly great work, Kurt - the long hours you spent were really worthwhile. It sets a standard for the rest of us to try to achieve!
Gary S.
1,576
Texas
Exactly! Kurt is giving me low self-esteem.:cool:
cnw1961
846
Germany
Thank you all for you very kind and encouraging comments. I really appreciate it. :wave:
Tetters, yes, it is going on the right side of my shelf layout.
No, not really. Jess, Gary, I hope this post will show you that it is nothing but a rumor. :mrgreen:
Today I tried to find a way to model the roof vents (is it that, what these hut-like structures on the roofs are called? I would not even know how to call them in German :eek:ops:). In pictures of models of the packing house I saw, that the roof vents were all built with solid wooden sides instead of louvers with single slates as on the prototype, so they did not help. Here is what I managed to do. I did not take any pictures while building it, because I was too curious to see if it would work out. But I still have two more left to do, so I can take some pictures then.
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
In pictures of models of the packing house I saw, that the roof vents were all built with solid wooden sides instead of louvers with single slates as on the prototype.
I believe that on the prototype, some vents can be opened or closed. So maybe the model is showing a closed vent...? ;)
Andrew
cnw1961
846
Germany
Andrew, you are right, but the closed vents on the prototype still look like vents and not like a solid wall :wave:.
