Think Jays Galactica is lonely, need some help
Status
jwhawk04
Hey all am building Jays Galactica, and thought she needed a fleet. Found some bridge comander files and I degreeble them a tad. Have some PDO's of alot of the ships but I am horible at unfolding. Heres the links to the PDO's and some screenshots.
Gemini Traveler
Colonial Liner
and the Celestra
Here are the links to the files:
Free file hosting by Savefile.com
Will have more up soon will be nice to have the whole fleet hanging up. Jwhawk---
Kjev
Way cool. If I get the chance I can try to fiddle with them (although I'm still learning Pepakura). I've always wanted to see the prison barge and the Agro ship from the original series.
K'Jev
Paragon
Yes! Definitely wanted those models, especially the Liner. The sooner you release, the better.
Two requests: The Astral Queen and the Heavy Raider. The Bridge Commander mod should have them, right?
Master-Bruce
Excuse me guys. I have those meshes also, they're created by a guy I only know as "Coxxon".
They'd make great papermodels as the textures are very nice. However, if the meshes displayed are the same as the ones I have they have intersecting parts so would need work doing to them before unfolding straight away in Pepakura.
On the Olympic Carrier and Gemenon Liner models for example, the fins on the tail go right through the body of the ship.
They can still be done as papermodels I'm sure but just thought I'd try to help before spending alot of time in Pepakura only to find that the model won't assemble correctly.
Sorry if I've stepped on any toes.
jwhawk04
thats what I meant when I said I earlier when I degreebled them, I exported them with milkshap after deleting alot of small parts and intersecting ones. I still have more of the ships to export after I get the file size down so it doesn't crash pepakura and that I have removed alot of the intersecting parts. I just suck at unfolding
jwhawk04
Heres the Heavy raider not many intersecting parts I can see on the mesh, final fit of the parts might be sloppy and require trimming. Heres a screen shot and the PDO file note: because of the complex curves this will take a skilled unfolder to tackle.
and the file:
Master-Bruce
With the intersection sorted then they shouldn't be too hard to unfold. They're low poly meshes but good ones so there may be some tricky spots, I'll take a look at one.
Nothing
Longtime Member
these would be so awsome with Jay's stuff!! I hope we dont have to wait to long for someone to figure them out. I have no idea how to use the programs or id give it a go! :wave7:
Paragon
So is someone going to unfold these for the rest of us?
Just a suggestion to whoever does: try to remove some of the folds that are supposed to make curves, and make them curved, if at all possible.
sjsquirrel
Original Meshes?
Jwhawk---
Jayhawm,
Where'd you get the original meshes?
SJ
sjsquirrel
Gemini almost done
Here's a teaser for you. The Gemini is almost done.
Give me another day or two for the model, eight to ten weeks for the instructions sign1.
I still need to adjust a bunch of the parts so they'll assemble nicely, and clean up the fold lines, but it shouldn't take too long. Well, okay, maybe you better give me three or four days - I only get a couple hours each evening.
Anyway, I think this one will look great when it's put together.
By the way, does anyone know what size this ship is or care about scale?
As it is now the finished ship will be 6-7 inches long, and maybe 2-3 inches tall. I can resize it easily so let me know what you want.
Nothing
Longtime Member
right now i look like homer drooling over a donut!! i dont think scale is too much of an issue. none of the models out are to scale with eachother. I think what u have ( 6-7 in long) would be good. not too big and not too small.balloon6
Paragon
I suggest you remove the dotted lines from the engines, cylinders are both easier to roll than fold, and look better.
sjsquirrel
You bet!
I'll be doing that for sure, and lightening up the line color as well, so the lines that are left won't be so obvious.
SJ
Status
