Scenery base question
Kevinkrey
941
Saint Paul MN.
I am using pink insulation board for my scenery base but the pieces I cut to match the layout did not join together properly, leaving gaps between the pieces? What can I use to fill the gaps between the pieces? The gaps are not huge, 1/4"-3/4" at most
Gary S.
1,576
Texas
Those are actually some pretty big gaps. Do you have any left-over foam? Cut that to fit and glue'er in is my suggestion. For smaller gaps, I have been using cheap latex caulk.
Jim Krause
1,270
Polson, MT
Anything rigid like plaster will tend to crack or shrink away from the foam if used on large gaps. I like the above suggestion.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Woodland Scenics makes a tub of foam that dries to about the same consistency as the extruded polystyrene. I use it for small imperfections -- like where the cat chewed on it. I don't think its economical for large gaps.
If the foam is held firmly in place, you could just start covering it with paper towel and your scenery base.
N
nachoman
You could also try the cans of "great stuff" insulating foam sold in home centers.
Kevin
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
You can also use "lightweight spackle" or "lightweight joint compund". I am pretty sure it is the same stuff. Dries to a foam-like consistency, rather than hard like plaster. You'll know you have the right container when you pick it up, because it's about 1/4 the weight of the premixed drywall compound.
I like the suggestion of "Great Stuff" expanding foam too, since it will help to stick the pieces together. However, it will also stick to just about anything else, so cover what you don't want "stuck"... ;)
Andrew
sumpter250
multiscale modelbuilder
Jan 19, 2002
3,073
Vernon Hills, Illinois
Yeah, Unless I slept through that part of the scenery class, foam is the modern replacement for cardboard strips, and screen, or crumpled up newspaper! It is the rough form of the final scene, which is done with plaster cloth, and hydrocal (plaster), or paper towels dipped in hydrocal. Finer detail can be added at any time after that, like ponds, rockwork, etc.. Foam buildups can also be added to change the scene as required, which are then also covered with plastercloth,or paper towels, and hydrocal.
:eek:ops: I am assuming that there is structural support under the foam.
Biased turkey
912
Montreal, Canada Eh
3/4" is quite a gap. I had the same problem, but the biggest gap is about 1/8".
I was able to fill that gap using GAP Kwickseal tub and tile adhesive caulk.
For a bigger gap, I would suggest to fill it the best you could with Sculptamold ( papier maché ), and allow it to dry for a few days ( of course it'll shrink a little ) .Then finish to close and seal the gap with the Kwickseal.
Here is a pic of what I did:
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
From the instruction notice about the DAP Kwickseal:
"Allow to dry at least 2 hours before painting with latex or oil-based paints"
So it shouldn't be a problem.
Jacques
Thanks for clarifying that the Kwikseal is paintable - I wasn't sure :eek:ops: But my point was basically if one does not choose that exact brand, do be sure to get something paintable...
:D
Andrew
Biased turkey
912
Montreal, Canada Eh
:D
Andrew
I agree 100% with you Andrew that any selected caulk should be paintable . I just wanted to confirm that the Kwickseal caulk is. And as far as I know the DAP brand is very common in US and here in Canada.
Good point Andrew
Jacques
