Weekly Photo Fun 8/17
chessie4155
1,206
Vincennes, Ind.
www.geocities.com
Scottsburg Local spoting a car at the truck terminal.
Herc Driver
1,474
North Carolina
Amtrak pulling out onto the mainline
A Phase IV P42 with a string of Superliners slowly starts out on today's Carolinian run. Although the Superliners are not normally used, they were out of position from an excursion trip and left in the Charlotte area and will be re-routed to Chicago after the arrival in the D.C. area. The P42 is one of the last Phase IV units that needs repainted to the Phase V coloring. Every once in a while, an older Phase III unit can still be found pulling the Carolinian as extra power to the newer Phase V units.
Flyboy41
38
Kentucky
The first locomotive I ever painted (three years ago) for my free-lanced N scale layout now under construction. SD35 high hood.
TruckLover
Mack CH613 & 53' Trailer
Apr 14, 2006
4,073
Rancho Santa Margarita, Cali.
Havnt contributed to the photo fun threads in a while. Heres some pics of my photo diorama im doing:
How it will all be layed out
The Beginning of the Left Side Embankment
Letf Side Embankment covered in WS plaster cloth
Roads Marked Out with WS paving tape
Road layed with WS SmoothIt
Left Side Embankment painted with FolkArt Honeycomb
Left Side Embankment covered in ground cover and rocks added up by track
Left Side Embankment finished exept for a few trees
Close-Up
Nuther Close-Up
Looking down next to the Bridge retaining wall
Road gaps filled in
Right Side Embankment laid using WS plaster cloth
Well thats where im at right now with it. Just waiting for the plaster cloth to dry so I can paint it and then get started with the scenery on that side.
You can see more picstures in my thread Building An HO Scale Photo Diorama. There is tons more pics in there, these are just the pics I posted for the photo fun thread :mrgreen:
cn nutbar
563
hello everyone---thanks for sharing all your great shots---herc,tom pm,nice to see you guys back on track---biased turkey,here's a shot you might enjoy
UP SD40-2
2,709
REALLY FANTASTIC SHOTS this week folks!!!:bravo:
i haven't had any time to take pics, model, or really anything lately:frowns: , but i found this pic i have never posted before:thumb: . hopefully this weekend i can find time to get some new shots:winki::119: .
KEEP 'EM COMING FOLKS!:mrgreen:
:deano: -Deano
UP SD40-2
2,709
Deano, I really like the way you build the roads on your layout. Do you have any link on that subject ( or better, any tutorial ) ?
Biased turkey, THANK YOU VERY MUCH for the complement:smilie: . yes, i posted how i do my roads in one of these weekly photo fun threads:winki: , but searching for it i realized it would be quicker to just repost how i do it:119: .
First i want to mention, some of the forum GREATS on here do MUCH BETTER roads then I:eek:ops: , take a look at Wayne's(doctorwayne) and Kurt's(cnw1961) roads for example...WOW!!!:eeki::thumb: , there are others too:thumb: , but Wayne and Kurt were the first two that came to mind:winki: . i know Kurt has a tutorial on here somewhere on his roads, and i am sure Wayne probably does too:winki: .
As for my roads, they are really quite simple:eek:ops::119: . i use styrene for the road, and paint it primer gray. at any auto parts store you can find white or yellow pin striping, thats what i use for the lines on the road:winki: . 1/16th for the lines, and 1/8th for stops, crosswalks, etc.
i use a mixture of Polly Scale "engine black" mixed with 70% strength isopropyl alcohol, about 1 tbl spoon paint to a pint of the alcohol, you might want to make it stronger or weaker to weather the roads. i "dry brush" the paint/alcohol mixture on the road where the tire tracks would be. be sure and put a light coat of the mixture over the whole road, and don't be afraid to leave some drips here and there to simulate oil spills:winki: . i also used a VERY FINE TIP black marker to draw in cracks in the road here and there:winki: . THATS IT!:mrgreen:
AGAIN, THANK YOU for the complement:smilie: , but check out some of the forum "GREATS" roads on here, before you settle for doing them like mine:winki: .
:deano: -Deano
Biased turkey
912
Montreal, Canada Eh
Thanks for the info Deano.
I'm surprised when you mention that you are just using painted styrene, because the result looks ( at least on the picture lol ) as good as if it was made using dry wall or spackling compound ( I think that's what DoctorWayne and CNW1961 are using ).
UP SD40-2
2,709
No problem:winki: , and THANKS!:smilie:
:deano: -Deano
cnw1961
846
Germany
Great pics this week, guys :thumb:. Sorry, no photo from me :cry:, I ran out of ideas :eek:ops: for pictures and I am too busy building my catalog house at the moment.
Biased turkey, don’t believe Deano when he says that my roads look better than his, he is just too humble as usual :mrgreen:. I don’t use dry wall or spackling compound, I like it quick, clean and easy just like Deano. I use 320 grit waterproof sanding paper to build my roads and paint it with thin acrylic paints. I haven’t done a tutorial yet (sorry Josh :neutral:, completely forgot about that), but here are two posts where I explain how I do it: http://forum.zealot.com/t111350-2/#post360779 , http://forum.zealot.com/t117064/#post428313 .
This pic shows you some painted and still unpainted roads.
doctorwayne
3,516
Canada, eh?
I don't think that I've done anything on roads either, as none of mine have been weathered. Here's a link to some level crossings, about the closest thing to roads that I could find, although these haven't been weathered either.
Level crossings...
Wayne
