Power-Sharing in the Past?
pgandw
Fred - I guess "quickly" is a relative term... ;) :rolleyes: hamr
The Newfoundland Railway was a narrow gauge road that came under the control of Canadian National after Newfoundland joined Canada in 1949. It's version of interchange involved bringing cars on a ferry, then lifting the bodies off the standard gauge trucks, and substituting narrow gauge ones. The load would remain in the body of the car. Once the job was complete, the process would be reversed, and the cars sent back to the "mainland".
Did any of the US narrow gauge lines do this for interchange?
All the tracks in NFLD have now been removed... :(
Andrew
The original Erie RR - 6ft gauge IIRC - used this technique. I think the East Broad Top, a coal hauling 3ft gauge also tried it. The D&RG used special idler flat cars to allow standard gauge engines to switch narrow gauge cars on thier dual gauge track yards and vice versa. Most narrow gauge lines (including EBT again) that hauled coal or other minerals in some form of bottom-unloading car ended up building trestles to unload these cars into standard gauge versions - a prototype for the famous Lionel coal trestle accessory!
Once interchange traffic became common, the non-isolated narrow gauge lines had to invent ways to more efficiently transfer freight then hand loading and unloading to survive. Swapping trucks was reasonably practical until the size of standard gauge cars became too big to ride safely on narrow gauge trucks or fit through the tight portals, bridges, and loading platforms. Your Newfoundland example had an advantage of being a closer fit to standard gauge practices than the US 3 ft lines orginally built in the 1870s and 1880s. And isolation always helped a non-standard gauge survive - the White Pass and Yukon being the best example.
The U.S. was a mess of gauges until the late 1860s. Everything from 2ft to 6ft gauge was commonly used. The Acts (1860s) authorizing and funding the transcontinental railroad(s) forced standardizing on 4ft 8.5in for all future construction receiving federal land or money grants. It also forced a maximum main line ruling grade of 2.2%, IIRC, to qualify for the fed $$. In 1869 (I believe), most all of the southern railroads which were predominantly 5ft gauge were converted to standard gauge on a single day. The Southern Pacific pulled a similar stunt in 1906 with the 3ft gauge NWP/NPC in coastal Northern California.
Fascinating stuff
Triplex
They also had some engines fitted with off-center couplers, to switch the other gauge without an idler car.
Up until 1870, there were two main gauges in Canada, provincial gauge at 5'6" and a few standard gauge lines at 4'8½". While the interchange of cars was very limited, on some lines, such as the Brockville & Ottawa (today's CP Rail's Brockville and Chalk River subs - well the Chalk River sub only as far north as Sand Point), they had a unique way of changing the gauge on the trucks.
The cars would be rolled through a special set of tracks and the distance between the wheels would be widened or narrowed, depending on which direction the car would be going. The axles had "stops" on them which allowed the wheels to move in or out. This didn't last too long.
Just down the street (or rather the railway line) at Prescott, the provincially gauged Grand Trunk obtained running rights from the standard gauged Ottawa & Prescott (originally the Bytown & Prescott). There was dual gauge track from Prescott Junction down into Prescott.
On Easter Sunday, 1870, the Brockville & Ottawa (now called the Canada Central) changed all of their track from provincial gauge to standard gauge, the last railway line in Canada to do so. After 1870, there remained only one railway line on Provincial gauge - the Carillon & Grenville (on the north shore of the Ottawa River around Hawkesbury), a short portage railway to get steamer passengers around the Carillon rapids).
Bob M.
Triplex
I believe a more technically advanced version of this concept is in use on some passenger trains crossing the Spanish border.
Relic
pardon me if I seem a bit thick,but just so I got it, if I were watching a freight in the early '60's it would have very few "foreign" cars?
Thanks to you all, very interesting stuff
doctorwayne
Yeah, in the 1860s perhaps, but around here, in the 1950s, '60s or '70s, there were lots of "foreign" roadnames to be seen. :D :D
Wayne
kutler
CPR in the Diesel age
CPR seemed to lease units every winter, as they were perennially power short. (I think it was a corporate strategy). Old copies of Canadian Rail bear testement to the hoards of units. Off hand I can recall B&M RS-2s, F-units, B&LE F-units, LS&I alcos, IC C-630s, various units from precision national usually retired geeps or alcos. BAR f-units UP Fa-1s. There's certainly more.
Until the last decade CP leased a lot of units referred to as rent-a-wrecks. Currently CP leases units from CEFX long term and NREX short term.
RobertInOntario
Thanks -- this is interesting and helpful info. Cheers, Rob
60103
Pooh Bah
Rob: check out the magazine Branchline (published by Bytown Railway Society). At the back every month it has a page or two of locomotive news -- listing leased units, both in and out, among the dead, repaired and stored units.
kutler
Canadian Rail
In the 60s and 70s "Canadian Rail" a publication of a Canadian Railway Historical assoc had fabulous information and photos of leased equipment. Notes credited to a "B Chapman" are highly reliable.
"B Chapman", who I personally know, can tell you the location of the train in Eastern Ontario simply by looking at the telegraph poles. He and some friends are taking their Kodak Super8 movies that they took in the 60s and 70s and putting them on DVD for sale. This is fantastic footage. Unfortunately, no sound but the DVDs bring back to life the railway lines that have long been abandoned.
Bob M.
Bob M.
kutler
Bob M.
Bob M.
Feel free to provide information as to how such DVD could be purchased.
