Tyco & Mehano (IHC) Products
RobertInOntario
1,384
Toronto, Ontario, Canada
Is there a connection between Tyco & IHC/Mehano? Just curious if anyone could please let me know if IHC bought out Tyco or if the two partnered in any way.
I have a few IHC products and, overall, their quality is good. I'm also curious if anyone can comment on Tyco's quality. I do have a few of those and I think it's kind of hit and miss (i.e. some are good, others not).
Thanks,
Rob
4,501
Lakewood, Ca.
Tyco's quality varied over the years. They went through a bunch of owners, some interested in building quality, others just looking to sell toys as cheap as possible. Mantua had some of the same problems with some of their diesels. Some had a drive similar to Athearn and were quality products, other years under different ownership, they had the pancake motor drives like the rest of the toys.
I think IHC and Mehano have been more consistent over the years.
RobertInOntario
1,384
Thanks, Russ. I think I've definitely got 1-2 of the cheaper ones (one has a pancake motor) and possibly one of their better ones. Rob
Justin
32
TYCO's made it over to IHC and Mehanodid importing for MFG and Mehanos suck because of their cheapiness lacking off flywheels and all wheel pick up!
msowsun
108
Oakville, Ontario
TYCO's made it over to IHC and Mehano did importing for MFG and Mehanos suck because of their cheapiness lacking off flywheels and all wheel pick up!
Justin, can you explain what you mean by "TYCO's made it over to IHC"? And what is MFG?
Also, you are a little behind the times. IHC Diesel Locomotives (made by Mehano) now have flywheels and all-wheel drive. They run quite well.
http://www.ihc-hobby.com/cgi-bin/bsc.cgi?sn=1P65G410186450374DO11252UD9926
Product Features
Powerful can motor
Dual brass flywheels
Precision gear transmission
Full 12-wheel drive
Smooth, quiet mechanism
Excellent low speed control
RP25 contour wheels
Cast metal frame
Diode-controlled directional lighting
Finely molded details
Kadee ready coupler pockets
Negotiates 18" radius curves
green_elite_cab
Keep It Moving!
Apr 4, 2005
1,876
Hainesport NJ
IHC's GG-1s bug me. Not so much that the paint schemes are crazy, but the shell is just dead wrong, for no apperent reason. the cab windows are slanted back wrong (it should slant the same way all the way across the cab, not pull back at the windows). Also, the nose is much more blunt, but i could live with that.
RobertInOntario
1,384
I have 3 IHC locos. Overall, they're pretty good. They run really well and smoothly but their detailing isn't the absolute best. These locos are quite affordable and, for what you pay, the detailing is good.
Sometimes I compare my IHC CN Hudson (which cost only $50) with a high end one that's for sale for over $800 from a LHS. The $800 one obviously has MUCH better detailing, but there's no way I'm spending $800 on a loco!
Rob
doctorwayne
3,516
Canada, eh?
The handrails aren't as thick as I feared... but I noticed some really strange couplers.
Link & pin: Those are the "pin" part! :rolleyes: :wink:
The only IHC loco that I have is the 2-6-0 Mogul, which runs fairly well, although its required starting current is a bit high. My smaller brass Mogul starts, runs and pulls better, but I often doublehead the two. Some day I'll get around to putting a can motor in her, which should be a simple job. I did turn-down the oversize wheel flanges, using a cut-off disc in my Dremel.
Wayne
msowsun
108
Oakville, Ontario
AHM used to import Rivarossi. I think the owners of AHM became the owners of IHC.
IHC's passenger cars are vaguely similar to Rivarossi, but they are not the same. They are a mishmash of fictitious cars that do not look quite right. The heavyweights in particular are not accurate for any passenger cars ever made.
toys2nv
13
Tottenham, Ontario
Hi all. has anyone had a look at the President's Choice sets? They are IHC
this is the IHC 2-10-2 in CNR loco 4100.
they are not bad. Runs very smoothly, low noise. The detail is pretty good. Any price very attractive. New in the store they run about 100.00 CND. I picked up two new sealed sets with nickel silver track for 55.00 each.
toys2nv
13
Tottenham, Ontario
they are usually in Loblaws stores or stores that sell PC products around Christmas. later on the blow them out. I found the ones I bought on the Craigslist in Toronto. He listed one. I bought it and I then found out he had 3 of them. I am picking up one more this week. I can check on the 3rd on if someone is interested?
