Reader's Digest Makes N Scale Locos??
once you have replaced the Horribly Oversized handrails with N-scale LL GP38's handrails they look better. but they still will not run :confused:
C
Catt
Ya clean up the handrails with a fresh Exacto blade ,install some dummy knuckle couplers weather the h*ll out of them ( they are SP afterall) then put them in your deadline with some Model Power or Lifelike & Bachmann clunkers.(this is not a dig at either maker their bad ones are just cheaper to buy)
Or put them on Ebay as rare collectables at a $10.00 starting bid and wonder why people are actually bidding on them.
Cannonball
More Trains Than Brains
ezdays
Out AZ way
I think you'd do better if you also say that you found them in your great-grandfather's attic this way and upped the starting bid to $50..:rolleyes: :rolleyes: :rolleyes: :rolleyes:
TrainNut
Ditat Deus
I had one of these things that I tried to modify for my 4 year old to play with. I found it in a garbage box at the club a while ago. The first thing I did was took out the dremel tool and modified the undercarriage so the trucks would swivel enough so he could push it around the curves. Then, we discovered that the couplers were pretty much useless and you could not hook ANYTHING up to it. I tried to find it just now so I could take a picture for ya'll but couldn't. My guess is it found its way to the trash can (again).
SP GP40 #9725 No. 418 "High Speed"
well i finally started working on the locomotives and here is a picture
SP_9725_army - Hobby Photo Gallery - Zealot.com
well a link at least
anyways The top has been painted Camo....it has a New cab(from an GP38-2 LL) New trucks (LL Proto 1000 SW8 ) and i scrapped of the hand rails....it has no feul tank though(any one want to part with some GP38 items like oh say a fuel tank and some handrails?:mrgreen:)
The bottom Loco is the original but with new handrails (GP38-2 LL junk line)
TrainNut
Ditat Deus
Looks like that was a fun project. Ever since I pulled mine out of the box for the picture above, it's been sitting in my yard. It looks okay from a distance but it could use a little of that TLC that you've given yours!
stary
I have one of those that I keep as a decoration, on top of the TV sitting on a small length of straight track.
