Best way to cut styrofoam?
HO Newbie
11
Thorofare, New Jersey
Hi there, I am new to the Gauge Forums, as a matter of fact I have never posted in a forum before this. I have been reading your posts for several weeks to get my nerve up and enjoying everyones suggestions and expertise in various subjects! There are so many talented people here!
I was hoping that someone could tell me the easiest way to make straight clean cuts in styrofoam. I want to cut the foam and then carve it to look like cement block for the foundation of a building. So far I have been unsuccessful in making a clean cut?
Thanks for your help!
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Hi HO!
I don't know if there is a way to get a really good clean cut in styrofoam.
First you need the extruded styrofoam, not the beaded stuff used in packing.
I find that a Knife tends to wander a bit, either across the sheet or it isn't vertical. I think saws create a rough edge and a lot of sawdust.
What has worked for me is the hot wire tool with some guides. I use stripwood - half-inch or inch wide, 1/8" thick, and tack a piece on each side or the foam with little pins. Take some time because the pieces have to be exactly opposite. You need to have the foam cut to within a couple of inches of where you want the final edge. Then run the hot wire down the foam, resting it against the stripwood. Just watch that there aren't any splinters or snags on the edge, and make sure you have enough power cord to get to the end of your cut. Any snags are going to show in your final edge.
(This is my 4000th post!)
hooknlad
396
Woodbridge, NJ USA
While at work today, i needed to cut some styrofoam sheeting ( the blue stuff used for insulation ). I scored it with an ordinary razor knife, then snapped it into shape.. Very easy to do.. Hope that helped...
doctorwayne
3,516
Canada, eh?
I've had good results using a panelling blade in my Skil saw, and of course, a straightedge. (This was for a reno project, nothing to do with trains.) :)
Wayne
diesel
NYC
www.empirevalleyrr.org
I use my well sharpened Swiss army knife.
YUP! A well sharpened Swiss/pocket Knife will do that pink/blue foam clean. If your not worried about a clean edge, a large serated (toothed) kitchen knife is fastest, and if you have a ginsu or ginsu knockoff (no kidding) that will cut a little cleaner and faster still, but not as clean as the swiss army knife.
w8jy
137
Au Gres, Michigan
I know that knives and hot wires are the most popular ways to cut the pink/blue foam, but I find myself straying off the cut line using those methods.
I use a 1/4" blade in my bandsaw and have no problems staying on the cut line. Unless you feed the foam VERY slowly past the blade there is no problem with melting or burning. I also use the bandsaw for resawing (making the foam thinner) the foam with no problems.
