Y-WING BUILD - Construction continues...
Chuffy70
842
1,709
Norwich UK
With a love of Star Wars and the many star ships and vehicles within the universe, the Y-Wing or The Koensayr BTL Y-wing assault starfighter/bomber has to be my favourite.
Generally considered to be the workhorse to the the more glamorous X-Wing. A kind of real world comparison could be the Hurricane to Spitfire.
Anyway, I've had a go at the Y-wing before, but that was a disaster of a build - a small kit, blown to large print on horrible stock, which resulted in me dumping it, although it did go to a home for rescued and unloved spaceships.
This build was forwarded to me for my perusal and thought it would make for a good trial on newly acquired cardstock. The only thing I know of the kit builder on this one, is that his name is Stephen.
There's no instructions with this build, but as its a favourite of mine, identifying the pieces shouldn't prove too much bother.
Below is the truly awful attempt - built from a table top gaming pattern.
test parts for this build are just the cockpit section
Internal parts acquired for cockpit
All folded and formed - well as far as I could tell without instructions!
Rear of cockpit bits and bobs
Cockpit window frame located
...and finished internals and cockpit frame
The newly sourced cardstock made this build a delight to make, although a wee bit frustrating as to the location of parts.
I'm not sure if I'll build the rest, but if there's enough interest I may carry on.
MTFBWY
mijob
Tie designer
3,249
5,486
95
Netherlands
Wow you are of for a great start it looks verry crisp and clear. For sure I gone watch this trhead.
Reactions: Chuffy70
Chuffy70
842
1,709
Norwich UK
This looks really good! You are off to a great start!
I have the same template. However, mine included this assembly diagram. I hope that it will help you.
Cheers for the template Chris, which is good for the first one I built, as pictured at the top - but the creator of this more detailed version has 5 CGI pictures with his files and that's it - did anyone else build this one or am I the guinea pig here?
10,001
I am glad to be of help.
Sadly, I think that you are the guinea pig on the second one. I am looking forward to seeing how this one turns out!
Reactions: mijob
12,458
Yes, it seems that you are the first one aside from the original creator. This model is on my todo list since it is the most detailed Y-Wing papercraft available at the moment, so I may join the club one day. :)
Chuffy70
842
1,709
Norwich UK
Small amount of progress on the cockpit/nose section using up the rest of the good cardstock.
This included the top panel sections and the side skirt.
Well that's all for today on this one - will be picking up the rest of the fuselage soon, when the copy-shop has more decent cardstock.
12,458
Your cuts are very precise and clean. I really like how she's coming together! :)
